Results 1 to 10 of 26
Thread: Cost for sub installation
04-16-2016, 11:21 AM #1
I would like to hear thoughts on what some stereo work should cost. Currently boat has wires ran for sub, amps installed, sub already purchased, and towers good to go. The project is purchase of ported 12 inch sub box, installing that under helm, installing EQ, hooking the stuff up and tuning.
My question is how many hours and how much per hour would be reasonable? or would a stereo place charge by the job?2017 Supra SA
04-16-2016, 11:41 AM #2
$200. Only a couple hours work. But being a boat I'm sure they will try and rip you off. Have a stereo bud come over and have cold beer on hand.
Sent from my iPhone using Tapatalk2013 LSV Red/White
1100lb upgrades in each rear locker!
Stock 500 Bow ballast
650IBS
Manual Flow equipped
Boards
Hyperlite Hi-Fi "The Illest"
CWB AMG Carbon
Phase 5 Razz
Byerly Volt
4.6 Ronix Koal Fish
Phase Five Scamp (kiddos)
04-16-2016, 11:42 AM #3
04-16-2016, 11:49 AM #4
04-16-2016, 12:00 PM #5
Yea, a shop isn't going to touch a boat for $200 this time of year. A custom fab box will cost over $200 before the labor.
$1,000 is closer but it may go higher than that. It's going to take more time than you think to do it right ... measuring the boat and making sure it fits, building a box to spec, ported means more math for correct tuning, waterproofed?, build out of a facade?, etc.
Then tuning will take at minimum an hour, probably 2.
My boat is going to Earmark at the end of the week ... I'd be ecstatic about a bill under $500.
It will vary by shop because their end result expectations will differ.2016 Moomba Mojo
2006 Supra 24SSV - Traded
04-16-2016, 12:05 PM #6
1 shop may take a prebuilt box, slide it in under the helm, hook up the wires, fiddle with gains and send you on your way.
Another shop will build the box to the manufacturer specs, waterproof the box, put feet in the floor to elevate the box off the ground, build out a facade, and spend some time tuning each piece of equipment in the line with digital tuning equipment.
This time of year you might also find a longer lead time than you would expect to get the boat in the shop.2016 Moomba Mojo
04-16-2016, 12:09 PM #7
Ya I think $200 is very low. If I lived in Texas and close to Earmark I would just drop it off there! Or on East/West coast there are alot of experienced builders in marine applications.
Up here there are no Marine specific or experienced shops so on last boat I had a local shop (and friend of mine) build the sub enclosure and install.
Although it sounded great there were things I would have done alot differently and asked about but never got done.
So this time around I just did it all myself and did it right!! It's a ton of work to do it right but couldn't be happier with the results and had alot of extra coin in my pocket for other mods.
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
04-16-2016, 12:16 PM #8
04-16-2016, 12:17 PM #9
Did they give you an idea on how many hours they have in the Box?
2006 Supra 20 - Sold
2015 Supra SE450 - Sold
04-16-2016, 12:34 PM #10
