Results 1 to 2 of 2
Thread: Fuel Issues / Carb Issues?
07-07-2006, 03:11 AM #1Junior Member
- Jan 2004
- Gridley, CA
- 13
I own a 99 Outback LS with the 5.7L Carb Indmar motor. The first 3 times I went out this summer, boat ran great, no starting problem, no idle issues under load. Now, went camping for the 4th, immediately off the trailer I noticed the fuel pressure gauge, that I added, was at 0 but I could hear the fuel pump working. So I did the normal startup procedure, blower for 2 minutes, 3-4 pumps of the accelerator and the boat started and ran, then I put the throttle a 1/4 way down for higher rev and lifted the motor cover to see the gas pressure gauge was still at 0, but the boat was still running. Then I just thought the gauge was broken, but as soon as I moved into idle and tried to back off the trailer, it died. So I continued to crank same procedure boat started and I switched into reverse quickly and it stayed running, and off I went. From there on, it ran fine, then the next day, started fine, but left me stranded out in the middle, once again no fuel. I pumped the accelerator only to see nothing in the carb, then all of a sudden after pumping..., gas again and it ran fine. Anyone have any ideas?
Also, I need a new fuel pump and oil sending sensor on the back of the motor. Where can I order these parts?Jonathan And Andrea Smith
07-07-2006, 04:29 AM #2Senior Member
- Sep 2002
- Pennsylvania
- 106
Replying to Topic 'Fuel Issues / Carb Issues?'
Sounds like a bad fuel pump,,,, Did you consider replacing the fuel filter first?
Try skidim.com for the parts.
Good luck, E
starter issues
By todd in forum Service & RepairReplies: 10Last Post: 05-09-2009, 10:57 AM -
UPDATE: Carb/Fuel Issues... Boat Runs!
By AaronWhitt82 in forum Service & RepairReplies: 22Last Post: 10-15-2007, 09:53 PM -
several issues...any recourse?
By drob07 in forum Service & RepairReplies: 4Last Post: 08-12-2007, 06:45 PM -
Oil Issues
By carsondoc in forum Service & RepairReplies: 16Last Post: 04-26-2007, 11:05 PM -
More Trailer Issues
By TN_Boarder in forum Service & RepairReplies: 4Last Post: 06-16-2006, 12:38 PM
