Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Irondequoit Bay, NY
    I was going to order a light from these guys. Sounds like they sell good stuff
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
  2. #22
    Jan 2014
    Kelowna, BC Canada
    It is in transit now via USPS so I will post pix when I have it installed.
    2014 Black/White Mojo
    345HP Surf Motor
    1235 Prop
    Autoflow 2.0 Upgrade
    1100# FlyHigh Rears
    650# IBS
    4 x Exile SXT9q's w/ Exile 30.2 amp and Exile ZLD controller
    Exile Javelin Amp
    10" Rockford sub
  3. #23
    Jul 2009
    Marquette, Michigan
    FYI, I could not get their "y-knot" to fit on my Mojo. I used an extension to move it away from the transom, and that allowed me to screw it in, but the wakeplate was touching the light even in the full DOWN position. I just returned it today.
    2019 Moomba Mojo
  4. #24
    Dec 2015
    north texas
    Default any experience with these guys?
    I had to return mine too. I tried several different brass fittings to make 45/90 degree angles. It was either hitting plate or actuator every way I tried. The drain plug on mojo is very close to plate and has downward angle.
    I would add the light looked solid. The company was also good to help me try and make it work. Really wish it would have worked.
    2017 Supra SA
  5. #25
    Jan 2014
    Kelowna, BC Canada
    So finally got around to putting this on ... and yes it does not fit. Same issue as Russell - am in the process of returning it today. They said I could always drill another plug hole and use it that way. Not my ideal situation at all.
    What did you guys do? Just return it and move on? I am thinking maybe go with the surface mounted Dagon 5150s they have? 8K lumens per light.
    345HP Surf Motor
    1235 Prop
    1100# FlyHigh Rears
    650# IBS
    Exile Javelin Amp
    10" Rockford sub
  6. #26
    Dec 2015
    north texas
    I just sent back and have gone without.
    2017 Supra SA
  7. #27
    Jan 2014
    Kelowna, BC Canada
    Yeah I'm pretty disappointed with these guys overall. I specifically asked them multiple times if it would work on my boat and even sent in pix, and they assured me it would. Hopefully this post will save anyone else with a '14 Mojo from making the same mistake.
    345HP Surf Motor
    1235 Prop
    1100# FlyHigh Rears
    650# IBS
    Exile Javelin Amp
    10" Rockford sub
  8. #28
    Jul 2009
    Marquette, Michigan
    Quote Originally Posted by blackcup View Post
    HA! Exactly the same thing that I did. Sent pictures and everything before ordering. They assured me that it would work.
    2019 Moomba Mojo
