Results 1 to 10 of 10
    May 2014
    San Antonio/Canyon Lake, TX
    Default Where to get marine audio wiring
    Where are y'all sourcing your wiring for amps and speakers?
    2005 Outback LSV-Assault 325
    Arkansas
    http://www.knukonceptz.com/
    I've also used monoprice.com but I'd say the Knu stuff is nicer but more expensive.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    Pretty much same stuff I have always used, only complaint is stripping the larger wire, I have to use a razor.
    Really nice wire though, soft enough it form and shapes really well.
    [COLOR="#696969"]
    May 2013
    Spokane, WA
    Knukonceptz is on Amazon too. Got a smoking deal on 0awg wire. Shit is so flexible (copper clad)
    2013 LSV Red/White
    1100lb upgrades in each rear locker!
    Stock 500 Bow ballast
    650IBS
    Manual Flow equipped
    Boards
    Hyperlite Hi-Fi "The Illest"
    CWB AMG Carbon
    Phase 5 Razz
    Byerly Volt
    4.6 Ronix Koal Fish
    Phase Five Scamp (kiddos)
    May 2014
    Thanks guys. Y'all use their stuff for the speaker wire too? I think the wires in my tower right now are pretty small and crappy, I'd like to upgrade to 12 ga. for the 4 new XM9's!
    Yea basically the same stuff.
    My tower came with prewire in it for 4, but I still had to run lines for the 5-6 speaker and used this stuff. It gets pretty hard pulling these through at times due to the thickness.
    [COLOR="#696969"]
    Whatever you do, avoid the low cost lure of CCA wire. Many hack installers use this stuff to lower the bid and win the job. What is CCA wire? Copper-clad aluminum. Basically aluminum wire dipped in copper to provide the appearance of copper. It certainly offers an appealing face value based on the significantly lower cost per foot. A dead giveaway is that it weighs much less per a 50 foot roll than OFC wiring. CCA wiring gets twice as hot when carrying high current. So it wastes twice the energy. And the resulting voltage drop reduces the amplifier power that you so dearly paid for. Here's the worst part....the terminations. Everything appears fine for perhaps a season but eventually the terminations begin to arc and burn until the connections pass very little current. This stuff is junk.
    Aug 2014
    What size wire would you recommend for Kicker KMS674C HLCD set up on the tower? Im ordering the wire from Knukonceptz. Thanks.
    Matt
    Oct 2010
    Lake Wylie NC Area
    Medic,
    That depends on the amp wattage, more so than the speaker. However, pushing the KMS67 to their potential, 14ga pair for each side, will do. If you need further details, dont hesitate to seek out advice from your Kicker dealer. They will know the ideal amp and proper cabling size for that application.
    Aug 2014
    Thanks.
    Matt
