Results 21 to 30 of 46
Thread: My Spring projects have begun...
03-19-2016, 09:40 PM #21
Awesome upgrades! Nice work.
Triple check that thru-hull before cutting. If it's a tapered thread then it can't be cut down. I learned this one the hard way...
03-19-2016, 09:54 PM #22
Ahh good call, I will check that first!
2013 Outback V
03-19-2016, 10:21 PM #23
Are you planning to pull up the carpet or just put the miners moss on top?
Mike
2013 Outback V
- FAE
- DIY suckgate
03-20-2016, 02:49 PM #24Senior Member
- Nov 2014
- Columbus, Ohio
- 388
Looking good! I also have a long list of winter upgrades that include miners moss on the floor, keep the pictures coming!
03-20-2016, 05:07 PM #25
03-20-2016, 05:09 PM #26
Seem looks pretty good - I'm sure once it warms up in the sun for a bit the wrinkles from shipping will flatten out nicely;
2013 Outback V
03-20-2016, 08:53 PM #27Senior Member
- Aug 2015
- Ohio
- 240
Looks good. Did you just seam it like they show on the decadence videos? Cut at slight angle then use pvc glue? The real question is, how does it feel on your feet
2014 Mondo
2013 Yamaha AR192.... Long gone
03-20-2016, 09:37 PM #28
I sewed the underside seem with dental floss, then flipped it right side up, folded it in half and put Goop Extreme UV Stable glue down the entire length of the seam, laid it flat and put weight on top, seems to have worked like a charm.
My wife bought a door mat from Stanley Steamer the last time they cleaned our carpet - it's the same material as that. It's hard to describe, it's like a coarse texture made of a soft material - I wouldn't want to kneel on it all day, but it's definitely comfortable on the feet.2013 Outback V
03-20-2016, 09:38 PM #29
How thick is it Ian? I have Deckadence and feels fine on feet. If you go with dark color (mine is about same color as Ian's) it can still get warm but nothing like carpet. It's the best option imo.
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
03-21-2016, 01:08 AM #30
What is approx cost in the deckadance? Is it precut?
Boat and upgrades look great, as always, Ian. Love the small touches
Sent from my SM-G928V using Tapatalk2016 Moomba Mojo
2006 Supra 24SSV - Traded
