Results 131 to 140 of 158
Thread: 2016 Mojo Updates
05-02-2016, 08:54 AM #131
*earmark in Lewisville did the sub install and tune
Sent from my SM-G928V using Tapatalk2016 Moomba Mojo
2006 Supra 24SSV - Traded
05-02-2016, 10:36 AM #132
05-02-2016, 10:39 AM #133
05-02-2016, 11:15 PM #134
Dang Matt, I was there all day!
Ported boxes are past both of our knowledge. The 4" port makes the 12" woofer seem small. Also, knowing the equipment is tuned optimally is a nice piece of mind. I noticed a difference in the 10s vs my prior 10s, which were self tuned.
05-03-2016, 12:45 AM #135
2016 Mojo Updates
The LED strips I used were only 2 conductor and they were a PITA to solder, I can't imagine how much of a pain it is to solder the rgbs with what, 4 conductors?? That's gotta be hard
Sent from my iPhoneDavid
05-03-2016, 11:32 PM #136
2016 Mojo Updates
05-04-2016, 12:30 PM #137
Been there done that. Did you run wetsounds RGB rings?
-Mark
"Hey you only live once"
05-04-2016, 09:42 PM #138
The inboats are wetsounds rgb in boats with led in the cone. . I did not do rings on the in boats.
The wetsounds rings are in the tower speakers. The leds were swapped out from what they sent in the box. The 6 pin connector is required for the tower clamp, if you want everything hidden and swivel/quick release.
Sent from my SM-G928V using TapatalkLast edited by KG's Supra24; 05-04-2016 at 09:49 PM.
2016 Moomba Mojo
05-04-2016, 10:38 PM #139
05-04-2016, 11:13 PM #1402016 Moomba Mojo
