Results 1 to 10 of 12
    Jan 2014
    Kelowna, BC Canada
    Default Auto flow on 2014 Mojo?
    Hey guys ... did a quick search and didn't see much. Has anyone had any success getting the auto flow installed on a 2014 Mojo? We have the manual surf plates but I am getting sick of switching them back and forth. Would be interested in jumping right up to the 2.0 system.
    Thanks!
    2014 Black/White Mojo
    345HP Surf Motor
    1235 Prop
    Autoflow 2.0 Upgrade
    1100# FlyHigh Rears
    650# IBS
    4 x Exile SXT9q's w/ Exile 30.2 amp and Exile ZLD controller
    Exile Javelin Amp
    10" Rockford sub
    Jan 2014
    Kelowna, BC Canada
    From my knowledge, the Autoflow wasnt released until the 2015 line correct? Can anyone confirm?
    345HP Surf Motor
    1235 Prop
    1100# FlyHigh Rears
    650# IBS
    Exile Javelin Amp
    10" Rockford sub
    I had it on my 2015 Mondo and loved it. I didn't want to mess with manual tabs either. I'm sure you can have them installed but I'm sure it's not cheap.
    Feb 2014
    I was just at the boat show and asked my dealer. I own a 14 Moomba. They said for $2500 the will install. Two plates, new front bag, switches and they have to flash the computer.
    2014 Moomba Mondo
    May 2014
    Palm Desert, CA
    I would consider going straight to the source.... www.wakelandmfg.com
    It's the OEM, but they sell a retrofit kit that looks pretty awesome. Same as auto flow but different controller.
    Worth a shot.
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
    Apr 2013
    Quote Originally Posted by BrettLee3232 View Post
    Worth a shot.
    Thanks for the link.. I've written asking if it works with 2013 LSV. Currently looking at options to upgrade my 2013... If it is compatible and I get a price, I'll post back... I'm writing my dealer to find out about manual Flow as well... It was originally 1400$ installed, but last year for some reason skyrocketed to over 2500$... I'm following up with them to see if it has come down this year at all. Currently I'm looking at cheaper wedge or ghetto gate...
    2014 Moomba Mojo 2.5
    2013 Moomba LSV (Sold)
    2013 Moomba Outback V (Sold)
    2002 Mastercraft X-5
    Jan 2014
    Kelowna, BC Canada
    Great thanks for the info. I emailed my dealer and waiting for a quote from manual to auto flow. Will let you guys know how close it is to the $2500 quoted above. If it is close to that then I will have a manual flow for sale if anyone is interested.
    345HP Surf Motor
    1235 Prop
    1100# FlyHigh Rears
    650# IBS
    Exile Javelin Amp
    10" Rockford sub
    For the 14 up boats you can use Auto Flow, this is because the dash computer is already updated for it.
    2500 is honestly pretty cheap as the units sell for that much with out installation. If you dealer is adding that, IBS and installation for all one price thats pretty dam nice as an after purchase upgrade, and not being done at time of New boat purchase.
    For boats with Manual Flow you will be paying closer to 4-5K for the switch over.
    You will have to have the Flow removed and the rear glassed back in before they can install the new 2.0.
    Expect 1-1500 for glass work as this seems to be the going rate on it from a dealer.
    Then figure 2-3K for the Flow 2.0 and this may or may not be installed.
    500-750 would be the expected labor to install the Flow 2.0
    I am working this process through as we speak to upgrade my 13 Mojo from Manual Flow to Go Surf Assist System Wake Makers is using.
    Jan 2014
    Kelowna, BC Canada
    Ok thanks for the info. I'm interested in seeing how your project turns out!
    345HP Surf Motor
    1235 Prop
    1100# FlyHigh Rears
    650# IBS
    Exile Javelin Amp
    10" Rockford sub
    Jan 2014
    Kelowna, BC Canada
    You were bang on ... just got a quote back from the dealer:
    Jay,
    The kit itself is $2,475. I would estimate 4HR labor to install (we are $130/hr)
    A big expense in this swap that I confirmed with Skiers Choice; is the gelcoat work. When the old flow system is removed there will need to be gelcoat/fiberglass work to fill the holes the old manual flow used. We don’t have a gel coater in house here to get an estimate but I would imagine it would add around $1,500 for the swap.
    So $4500 sounds about right.
    345HP Surf Motor
    1235 Prop
    1100# FlyHigh Rears
    650# IBS
    Exile Javelin Amp
    10" Rockford sub
