Results 21 to 27 of 27
Thread: FAE install on MOJO
02-23-2016, 03:02 PM #21
I do not have a gap
2006 Supra 20 - Sold
2015 Supra SE450 - Sold
02-23-2016, 03:03 PM #22
FAE install on MOJO
Here are a few more photos
02-24-2016, 12:31 AM #23Senior Member
- Mar 2015
- 134
Thanks Dusty. The pictures are helpful.
The exhaust output flange on your supra is different from my Mojo.2015 Mojo Surf Edition
1100 rear lockers
400+ under each rear seat
700 stock center
950 ibs
autoflow 2.0 surf tab upgrade
FAE
02-24-2016, 11:16 PM #24
This will mount like all the other Moomba boats to the exhaust flange.
The rubber flap has a band clamp you remove, then it pulls off and you have a plastic exhaust flange. FAE will send you an aluminum insert so you can mount the rubber hose from the FAE pipe to it. This tends to fail. So most screw the rubber extension hose from the FAE to the plastic exhaust flange.
I know yours is a solo due to Raptor engine but still same concept.
Before with Rubber Flaps.
This just shows how the Rubber boot goes from the FAE over the outside diameter of the Exhaust flange. I put 4 screws through the rubber boot into the plastic flange, then used a band clamp over the screws so they can't back out. 5 seasons and never an issue on 2 boats.
[COLOR="#696969"]
02-26-2016, 05:06 PM #25Senior Member
- Mar 2015
- 134
Thanks Mandley.
Mine is built without the rubber connection similar to Dusty's, but will fit over the protruding flange of the exhaust outlet like your rubber hose does. A metal lip on the FAE abuts the lip of the exhaust outlet and the four screws of the exhaust outlet hold everything on.
The FAE to exhaust outlet junction is very tight, thus my question to Dusty about whether he had to sand his down to get it to fit. His outlet is a different design then ours as you and I now know.
FAE is working hard to get everything perfect. This is a new model for them.
Bill2015 Mojo Surf Edition
1100 rear lockers
700 stock center
950 ibs
FAE
02-26-2016, 08:53 PM #26
I order fae back in the fall group buy and it didn't fit correct I've sent mine back to Larry for mods. I had a 1/4 to 3/8 gap from the outlet to the flange.
2015 Supra SG 450 Fire Red Metallic
Wetsounds and MMATS
2015 Mojo
2014 LSV
2006 Tahoe Q4sf
02-27-2016, 12:16 AM #27Senior Member
- Mar 2015
- 134
nitrodude,
Have you received your final product back yet?
I ordered mine in the fall group buy as well, but was not able to submit my boat's measurements until after
christmas so am only receiving mine now.
What was your solution to the tight flange to exhaust outlet fit?
Bill Z2015 Mojo Surf Edition
1100 rear lockers
700 stock center
950 ibs
FAE
