Results 11 to 20 of 27
Thread: FAE install on MOJO
02-22-2016, 12:45 PM #11Senior Member
- Mar 2015
- 134
Dusty
PM sent.
Thanks for sharing.
Am I correct that your support mounts to the drain plug? Did you consider mounting to the trim tab actuator attachment to the transom?2015 Mojo Surf Edition
1100 rear lockers
400+ under each rear seat
700 stock center
950 ibs
autoflow 2.0 surf tab upgrade
FAE
02-22-2016, 12:50 PM #12Senior Member
- Mar 2015
- 134
I am aware of the different mounts. Wakeland says the 1.0 mounts will be adequate. We shall see. I tried to also order the 2.0 mounts from them to have on hand just in case, but that seemed to be complicating the order of the plates so I only ordered those. Changing brackets would be complicated by the electrical wire so it is simpler not to change.
1100 rear lockers
700 stock center
950 ibs
FAE
02-22-2016, 01:20 PM #13
02-22-2016, 01:28 PM #14
When I bought the craz I was told the fae isn't really needed with the new technology. These new models do a great job at both getting rid of the bad stuff and staying quiet. I can't speak to how much more quiet my new boat would be with a fae, but I can tell you turn key this thing is WAY quieter than my old tige
Sent from my SAMSUNG-SM-G900A using Tapatalk
02-22-2016, 01:29 PM #15
02-22-2016, 01:29 PM #16Senior Member
- Mar 2015
- 134
02-22-2016, 01:30 PM #17
Actuator was discussed when designing but the drain plug was decided on.
2006 Supra 20 - Sold
2015 Supra SE450 - Sold
02-22-2016, 03:41 PM #18
02-22-2016, 09:32 PM #19
The tabs are enormous on the new boats!
02-23-2016, 02:14 PM #20Senior Member
- Mar 2015
- 134
Dusty,
One other question.
When mounting the FAE to the boat exhaust flange, how tight a fit was it? Did you have to sand down the flange some to get it all the way on? Does the FAE flange seat firmly against the lip of the exhaust flange or is there a gap?
Thanks.2015 Mojo Surf Edition
1100 rear lockers
700 stock center
950 ibs
FAE
