Results 1 to 8 of 8
Thread: Help me trouble shoot sacks
06-28-2006, 09:03 AM #1Senior Member
- Oct 2003
- Northern Kentucky
- 110
Only complaint I have ever had with my boat in the three years I have owned it is the sacks have never worked, at least the fill function. They will empty if I pump them manually, so I know the pumps are good. I have tried priming them, running at around 10-15mph with the ballast switch on, but nothing. I can hear the pumps running when I turn them on, so thats ok. Got under the boat and unhooked the pumps and stuck a dowel through the hole, so its not clogged. I have tried turning on both switches at the same time, thinking maybe I could catch the vacuum and get it going. Nothing. No idea where to go from here. Talk to me.
06-28-2006, 09:54 AM #2Senior Member
- Sep 2005
- Austin, Tejas
- 491
Replying to Topic 'Help me trouble shoot sacks'
sounds like the pump isn't priming, I would disconnect the inlet hose on the sac and suck on it a little while the pump is on. It sucks doing that, but it works every time. IT will suck water up to the pump and start the prime and the pump will do the rest.
06-28-2006, 01:45 PM #3Senior Member
- Oct 2003
- Northern Kentucky
- 110
Thanks for the reply. Will I have to do that everytime? I may just replace the pumps if that is the case.
06-30-2006, 09:38 AM #4
Are you flipping the toggles on the pumps to prime?
Pete
07-01-2006, 01:05 AM #5Senior Member
- Jul 2003
- 340
One other thing that I can think of. Has the ball valve on the through hull water inlet been shut off. At least on my boat, the inlet comes through the bottom of the hull and has a 90 degree elbow. The shutoff valve is then mounted before the pump. If it's closed, you wouldn't be able to tell by pushing a dowel rod into the inlet.
07-02-2006, 09:25 AM #6Senior Member
- Oct 2003
- Northern Kentucky
- 110
"Are you flipping the toggles on the pumps to prime? "
Nope. Please explain? What toggles? As for the ball valve, you mean on the main line coming through the hull? I have tried both ways, open and closed, just in case the were put in wrong.
07-02-2006, 09:35 AM #7Senior Member
- Mar 2004
- Wylie, Tx.
- 212
With my 06 XLV I have to get on plane and turn the fill switches off and on about 10 times and that gets rid of the air bubble in the screen to allow the sacks to fill. This is dinda a pain, but better than having to prime the pumps by hand every time. Try that and see if that works.
MedicMedic151
06 Mobius XLV
07-03-2006, 10:50 AM #8
On my boat each sack has its own solenoid. On each solenoid there is a little black toggle , in one position the sacks will fill when you are crusing, this also how your prime the system. In the other position they will fill only when you turn the switch on the dash. If the you are having trouble filling the sacks using the main pump switches on the dash, you may need to flip the toggles on the solenoids to prime the system, once primed, you can flip the toggles back and fill and drain as designed.
When I first bought my boat I notice my sacks were filling on their own, this is how I found out about the toggles.
Pete
Carb Trouble
By Storm in forum General ChatReplies: 18Last Post: 03-18-2007, 12:14 AM -
Ballast fill trouble?
By MEDIC151 in forum General ChatReplies: 5Last Post: 06-05-2006, 10:36 PM -
posting trouble
By james yarosz in forum General ChatReplies: 1Last Post: 04-14-2004, 12:58 AM -
trouble posting
By james yarosz in forum General ChatReplies: 0Last Post: 04-07-2004, 09:10 PM -
Trouble With Tach
By Bobby in forum Service & RepairReplies: 3Last Post: 03-04-2003, 12:45 AM
