Results 1 to 10 of 17
Thread: Two Speedometers?
06-26-2006, 04:23 PM #1
Two Speedometers?
This may seem like a stupid question and don't ask why I'm just now asking this since I've had my Mobius for 4 years now but...does anyone know why there are two speedometers on the dash? I'm thinking of pulling one out and putting in the Pefect Pass system in it's place. However, I don't want to screw anything up should they be linked together somehow. Thanks,
Jon...Dead dinosaurs keep me from paddling...
06-26-2006, 04:27 PM #2Senior Member
- Aug 2002
- Bismarck, NorthDakota
- 579
Replying to Topic 'Two Speedometers?'
It is a requirement for tournament ski boats.
I don't think they are linked in anyway and I highly recommend a perfect pass.
I don't know ANYONE how has PP that does not swear by it!Bruce Fuerstenberg
06-26-2006, 04:59 PM #3Senior Member
- Mar 2006
- Chapin, SC
- 159
Its always been two for tournament ski boats... perhaps there was a fear of one breaking... definately get PP and remove one of the Speedo's.. I got mine from skidim.com and he ordered me the white moomba logo display so it looks factory. The tuning knob on the speedo will have to be cut so you can screw your knob back on. This way you wont have a hole in your dash.
I mess with Texas
06-26-2006, 05:04 PM #4
Thanks for the info guys. Speaking of that tuning knob, I always seem to spin it around wiping the boat down, etc. hence messing up my speed setting. I can usually get it close by pulling someone that I know likes the same speed everytime and watching their reaction but it would be nice to be more accurate. Is there a device out there than can accurately tell you your current speed? GPS?
06-26-2006, 05:09 PM #5Senior Member
- Feb 2006
- Reno, NV
- 168
I keep my handheld GPS in the glovebox so that I can calibrate it each time out. I usually set the left one to wakeboarding speeds and the right on to slalom speeds as they are not entirely accurate.
I will be adding Perfect Pass to replace the right one next year.
Dave
06-26-2006, 05:09 PM #6Senior Member
- Mar 2006
- Chapin, SC
- 159
i time my PP with magnets in the slalom course and from there calibrate the digital speed display on PP. I do believe GPS can tell you the speed, but I have never tried it... there are plenty of others on here that probably know how to do that.
Good LuckI mess with Texas
06-26-2006, 05:35 PM #7Senior Member
- Dec 2005
- Ontario
- 531
I use a GPS to callibrate my speedos. One thing that you may want to keep in mind... I use my boat on a river with a slow current. when I go against the current the speed is exact when I go with the current the speedo will read anywhere from 1.5 to 2mph off what the actual speed is. I believe it is because the speedos are callibrated by the RPM of the engine.
2005 Moomba Outback
06-26-2006, 09:27 PM #8Member
- Aug 2005
- Las Vegas, Nevada
- 56
I also take my GPS every time i go out just in case i bump the calibration knobs. I may be corrected, but I believe that one is a paddle wheel speedo and the other is a pitot tube speedo. I just had Perfect Pass installed and they removed the right one which i believe is the paddle wheel and replaced it with the digital speedo.
06-26-2006, 10:07 PM #9
I do not remember seeing any pitot tubes on the boat. I am pretty sure that both speedos run off of the paddle wheel and the dual speedos are for failure purposes. If one speedo fails, the other one is used instead. Perfect pass and the remaining speedo both run off of the paddle wheel.
15 Mondo Surf Edition
02 LSV - Traded In
06-26-2006, 10:22 PM #10Senior Member
- Jul 2003
- 340
Smrtz,
Your speed is off because of the water current and not because the speedo was calibrated to rpm. The GPS is measuring your land speed only while the speedo is measure in the speed at which the water passes under the hull of your boat. If you set your speedo by your GPS going upstream, the speedo will always read the same as the GPS in that direction. Once you head downstream though, the GPS will show you as moving faster at the same indicated speed on the speedo. To help keep relative speed across the moving surface of the water the same in both directions to help out boarders or skiers you need to know the water current speed. Make a run upstream at a set speed on your GPS and see what your speedo says. Make a downstream run at the same speed on the GPS and see what the speedo says. Take the difference in speedo readings and you'll have your water current speed. Add that number to your GPS speed running upstream and subtract it going downstream and you'll have you actual water speed. In your case though, it sounds like the currect speed is slow enough that you wouldn't really notice a difference.
I think the whole dual speedo is still kind of a carry over from tournament requirements when boats all use the pitot tube speed pickups. Each speedo had its own pickup so they could be used independently to verify each other. Since paddlewheels have been in use, both speedos are wired to the same paddlewheel so there isn't really a way to use one to verify the other. I think they keep them both in there now for a few different reasons. One reason is simply because it's always been sort of a trademark and something that is different about tournament boats. Secondly because there is still a chance that a speedo could fail during a tournament and you'd need the second one as backup. Lastly, because perfect pass is becoming almost standard they just put it there if you don't get perfect pass so they don't have to change the dash or the build process around it thus making everything easier and more uniform.
Speedometers stopped working on 2005 Mobius LS
By pls4912 in forum Service & RepairReplies: 5Last Post: 07-25-2005, 11:59 AM -
Speedometers/Gauges
By mikeoc in forum Boat OwnersReplies: 7Last Post: 06-26-2003, 09:06 PM
