Thread: Cover help
    Default Cover help
    Alright, I know this is going to sound like a stupid question but I can not seem to figure out the poles on the cover for a DD? I leave the boat at the in-law’s lake house during the week, and water always seems to puddle on the cover by the time I get back.
    Should the poles on the side of the motor be higher than the pole behind the motor? Should the poles be the same height as the windshield? I know these is not rocket science but any tricks people have would be quite helpful.
    Dec 2005
    Ontario
    Default Replying to Topic 'Cover help'
    as long as they are elevated and there is no slack im not sure that you will get pooling. just make sure the tie downs are tight . if the cover is loose the water will always find a place to pool. make sure in the front you dont pull too tight or it will flatten out the cover from the nose to the pole and leave a spot where pooling can occur.
    just takes a bit of tinkering around... you'll get it no doubt..
    Cheers
    2005 Moomba Outback
    Jan 2003
    Minnesota and Wisconsin
    I only use 2 poles. The factory coper has sleeves for them built in. One is in the bow. One is right behind the motor. Seems to work fine if you draw the string tight and pull the straps tight.
    Dave
    I made a support out of 2 1/2" PVC schedule 80 pipe and fittings. I use a 90 degree to hook over the pylon, then a cuple of 4-way plus signs. I will try and get a picture of my conraption later this week. The advantage with this thing is that the poles don't fall over.
  1. 06 lvs cover
    By davidl in forum General Chat
    Last Post: 03-19-2007, 05:57 PM
  2. Looking for cover
    By kamberra02 in forum Service & Repair
    Last Post: 06-08-2006, 12:49 PM
  3. Bow Cover
    By Will Watters in forum General Chat
    Last Post: 02-16-2005, 07:51 PM
  4. Replacing my cover
    By jchamlee in forum General Chat
    Last Post: 01-05-2005, 09:42 AM
  5. Mobius Cover
    By cheeseinaz in forum General Chat
    Last Post: 09-02-2004, 12:51 PM
