Results 11 to 20 of 80
01-16-2016, 10:34 AM #11
Nice Dusty you nailed it! I still have 2 12w7's sitting around that I might have to have a project for. How many watts are you putting to the sub?
-Mark
"Hey you only live once"
01-16-2016, 10:39 AM #12
That looks super clean. I bet have the port compartment open from both ends really helps in working in there with the amps and wiring. It is sp hard for me to get back there in mine. I guess you mounted all the amps to the rack before installing the rack and then installed it all as one piece? This makes my install look like a kindergartners finger painting.
01-16-2016, 10:43 AM #13Senior Member
- Aug 2015
- Ohio
- 240
Wow!! Very Nice!
2014 Mondo
2013 Yamaha AR192.... Long gone
01-16-2016, 10:53 AM #14
Thanks guys, appreciate the comments.
Langston, the storage locker is insane. I am able to sit Indian style and not be hunched over while working in there. You are correct, once the panel comes off the entire rack can be disconnected and pulled from the boat if need be. The front and rear access makes it very convenient. The starboard side is the same in regards to accessing both sides which made securing the giant sub box very easy.
David, thank you sir. I bet a laid out all my wires 5 different directions on the rack before securing a single one! After install I found I brain farted on a single wire and I haven't gone back to correct yet. I took the advice you and Phil have traditionally offered and got power/ground for the zld direct from the sub amp since it is the largest. I mistakenly grabbed remote power from it rather than my remote power terminal block that feeds everything else. As soon as I flipped the switch the first time I had that little thump through the sub. I'll get that fixed soon!
Sent from my SAMSUNG-SM-G920A using Tapatalk2006 Supra 20 - Sold
2015 Supra SE450 - Sold
01-16-2016, 11:49 AM #15
That is nuts! Nice work Dusty. Was at the PDX boat show last night hoping to drool on an SE but they didn't have any on the floor.
01-16-2016, 12:16 PM #16
01-16-2016, 05:22 PM #17
Looks good Dusty! Very clean.
PWI as usual...
01-17-2016, 02:13 AM #18
Finished the updates on the new SE
So you went Surf 9s this time...
Matt
2021 Mojo
2016 Mojo (sold)
2012 LSV (sold)
01-17-2016, 12:40 PM #19
Very Nice work! Gotta love Audio Ballast.
With all that weight on the port side you are going to lean without counter weight! LOL
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
01-17-2016, 03:45 PM #20
Hey Dusty - Looks super fine. Or as Rabecka's daughter says, "that looks FLEAK". I gotta keep up with the new lingo man! really like the fit and finish level of detail you got going on. You've got to be mighty proud of this work friend. Bottom line--- hows it sound???? So glad to see you in that boat. It's #legitness
