Results 21 to 26 of 26
Thread: Wet Sounds 420 Install
01-08-2016, 05:38 PM #21
I'd have to see the back to be sure. (the posts should be labled on the back.) But yes, I would most certainly pull it out and look at the back.
If your suspicion is correct, your switch would likely operate as follows:
Position 1 - the boat electronics wouldn't run. all it's doing is joining the two batteries.
Position 2 - the boat is running off battery #2
Position 1+2 = the boat is running off boat batteries
Position 0 = the boat is either running off battery #1 or it's not powered.... that really depends on the internal workings of the switch which I don't know.
When you look at the back side, it'll be obvious. There's a terminal for battery "1" and a terminal for battery "2" and a "common" to hook up your load to (the wires going to the distro block and to the starter through the floor).
Bottom line, is that to make sure it's right and have peace of mind, get out your cordless drill with the screwdriver bit, and whip off that switch and look at the back of it and the labels on the back. Then grab a pair of pliers or a socket or a crescent wrench and do the swap-a-roo if necessary.2008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
www.TraysonsToybox.com
01-08-2016, 05:58 PM #22Gil Hebert
2014 Mojo
01-08-2016, 06:05 PM #23
01-09-2016, 11:40 AM #24
There really isnt any wiring for the "1/2 or BOTH" position as that connection is handled mechanically internal of the switch. The only real way to goof the switch wiring, is to put the the common cables on either the 1 or the 2 post and then one battery ends on the C and the other is on the remaining bank post. Sounds like you verified the batteries are on the 1 and 2 posts and all others are on the C post by looking at the back of the switch?
If so, you really need to get in there with a volt meter and start with making sure the batteries are charged. Then go to what doesnt work, and check for battery voltage on the proper wire and work back to the source, as in the switch, until you find where the voltage stops. This could be a breaker or fuse or bad switch.
01-09-2016, 12:00 PM #25Gil Hebert
2014 Mojo
01-12-2016, 12:35 PM #26
I'v confirmed my batteries are in very good shape, according to the local interstate store. I will reinstall them and see if I can replicate the issue I was having.
Gil Hebert
2014 Mojo
