Thread: Vibration over 10mph
06-25-2006, 09:35 AM #1Senior Member
- Mar 2004
- Wylie, Tx.
- 212
I noticed yesterday that I started getting a vibration while accelerating after about 10mph. I didn't hit anything and was wondering if this could be the shaft out of alignment? I have to take the boat in to have the shaft packing log replaced and thought that if it was out of alignment, it would start getting progressively worse. I have an 06 XLV. Any input would be appreciated.
MedicMedic151
06 Mobius XLV
06-26-2006, 06:06 AM #2
Replying to Topic 'Vibration over 10mph'
Anything wrapped around the shaft? That's about the speed when vibes start. I know this because of limping home w/ a ski rope in tow.
Crikey
06-26-2006, 10:05 AM #3Senior Member
- Mar 2004
- Wylie, Tx.
- 212
No, I have had hydrilla and a rope as well on my last boat, but that is not the case now. I looked at the prop and shaft when I got home from work this am, and the part that holds the shaft near the rudder does not look like it is inline with the rudder. I don't know if that is the way it is supposed to be to compensate for the rotation of the prop or not. I will be calling the dealer this morning as soon as they open.
MedicMedic151
06 Mobius XLV
06-26-2006, 11:21 PM #4
I think the strut (the part that holds the shaft near the rudder) is supposed to be perpendicular to the bottom of the boat. If not you definitely have a problem.
A bent srut would suggest that you hit something so look for marks on the drive shaft and the strut (as well as the propeller) and also on your trailer ....
DaveIf you believe something to be true, it will be - in it's consequences.
06-26-2006, 11:30 PM #5Senior Member
- Mar 2004
- Wylie, Tx.
- 212
I looked at the strut and it is not perpendicular to the hull. There are no marks on the shaft, hull, prop, trailer or rudder. I called the dealer and asked about it and he said that it would not be impossible for the shaft to be out of alignment so bad that the strut tourqed some. Seems like to me that the vibration would have been alot worse, but who knows. The shaft packing log was due to be replaced since they had a bad run of them on the 06 XLV's according to the dealer. They told me when I took it in for the 20 hour service that the shaft was out of alignment in the first place causing the rope packing seal to wear out faster than it was supposed to. I didn't get a call back from them today, but will let ya'll know what the outcome is one way or another. I hope this gets done soon, I have a 11 day trip to lake ouachita starting on july 11th. Can't go without it.
MedicMedic151
06 Mobius XLV
Vibration
By Longshore in forum Boat OwnersReplies: 2Last Post: 06-14-2007, 08:00 PM -
Hello Vibration!
By jpengelbrecht in forum Service & RepairReplies: 3Last Post: 08-30-2005, 02:44 PM -
Violent vibration
By clark in forum General ChatReplies: 4Last Post: 06-06-2005, 09:59 AM -
Vibration
By Allterr in forum Service & RepairReplies: 10Last Post: 04-16-2004, 07:49 PM -
Vibration
By MartyC in forum General ChatReplies: 6Last Post: 05-10-2003, 03:18 AM
