Results 1 to 10 of 12
Thread: Trailer light help??
10-11-2015, 03:31 PM #1
I have a 2012 boat mate trailer
The right side lights tail light and turn signals work
Left side does not
All running lights work both sides
Checked wires looks good
Could the 5 pin adapter to the gm round plug go bad on just one side ?
Any help would be greatA Day at the Lake...Priceless
10-11-2015, 03:41 PM #2
Did you check the tow vehicle? If not, check that. Then plug just the adapter in and check that. You need to narrow things down.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
10-11-2015, 04:08 PM #3
Tow vehicle is fine
10-11-2015, 06:30 PM #4
I had the same issue, turned out the left and right on the tow vehicle had different fuses.
Sent from my SM-G900V using Tapatalk2017 Centurion Ri237
2013 Supra SA450 - Sold
2006 Mobius LSV - Sold
2004 Stingray 190LS - Sold
10-11-2015, 06:33 PM #5
Adapter is fine. Really tough to isolate where the trailer fuses are
I did check but no issues there eitherA Day at the Lake...Priceless
10-12-2015, 10:31 AM #6
This happened on my 12 Mojo. It ended up being the 5 pin round adapter wasn't making good contact with tow vehicle. Took some sandpaper and roughed up connections and left side works again.
Shane
2016 Supra SE
EXILED
6 XM9 Tower
6 Wetsounds XS650 Cabin
1 EXILE BIG 12 DVC 2000 watt in a ported box
1 XM 15.4
XI 1500.1
2 MX 30.2
Wetsounds 420 EQ
EXILE Blue tooth EXBT4
Blue LEDs
10-12-2015, 01:07 PM #7Junior Member
- Aug 2015
- 23
Which GM vehicle is it? I can help with the 07-13 silverados (I have one). The fuses for towing are in the engine bay. Autozone carries a tester that plugs into the 7 to 4 pin adapter (or the 4 pin plug on your vehicle), it has lights that will come on to confirm that everything is working correctly in the tow vehicle.
10-12-2015, 01:52 PM #8
I have a Ram 1500, I had the similar issue, the running lights worked, but the turn/brake on one side (rt or lt i forget) did not work. I thought it was the boat trailer, til i hooked up a couple of my other trailers and the same side did not work, but they lights all worked on another vehicle. the ram has fuses for trailer that are different than other fuses. after a lot of looking, my brother said RTFM, we found the fuse pattern in the manual and got the fuse replaced. it was a mini micro fuse and hard to physically locate one to buy.
19 Mondo
08 LSV, forever loved
10-12-2015, 05:20 PM #9
I believe jmvotto said his truck and adapter were fine. This leads me to believe it is a loose or dirty connection at the light or trailer plug.
Joe
2014 LSV
1993 Echelon
10-12-2015, 06:02 PM #10Junior Member
- Oct 2015
- 6
This is where a good digital volt/ohm meter comes in handy. Along with some good troubleshooting. I'm an auto tech by trade, so this would be easy for me to isolate. If some lights work, that tells me the ground connection is good. Next you'll need to test one thing at a time. First test your truck without the adapter. Then plug in the adapter and test it. If that checks out, then you go to the lights themselves. Should be very simple to pinpoint where the issue lies.
2014 Moomba Mobius LSV
