Results 1 to 10 of 14
Thread: Just another tower light
10-06-2015, 06:49 PM #1
Here is my Moomba to Atwood adapter.ImageUploadedByTapatalk1444171761.728272.jpg
Sent from my iPhone using Tapatalk2008 Moomba Outback DD resurrection
10-06-2015, 08:31 PM #2
More details please.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
10-06-2015, 11:06 PM #3
Well I have a lathe and a mill.
I want the light on top of the tower so I spun this on the lathe. Then threw it on the mill. Spent way too much time tinkering. Then changed it again.
ImageUploadedByTapatalk1444187041.636078.jpgImageUploadedByTapatalk1444187062.502879.jpg
I cut a recess for the spool. Then I cut a centering bore for the towers stub.
10-06-2015, 11:11 PM #4
It has changed a bit tonight. Will take pics tomorrow. Damn little drill bit broke when I was drilling my tower. Everything was fine, 1 bolt (5mm) was bottoming out just a little too early. I snapped the bit in there. Not likely to get it out. Maybe I will try but in the mean time I just went from a 2 bolt to a 3 bolt pattern
10-06-2015, 11:14 PM #5
10-06-2015, 11:20 PM #6
Showing the revised bolt pattern since the broken bit in the tower stub changed my plan!
Disregard the chatter, patience wore thin. Plus it is not showing. It wont happen again.Last edited by Fastest1; 10-06-2015 at 11:34 PM.
10-06-2015, 11:23 PM #7
I trimmed it down a little more.ImageUploadedByTapatalk1444188185.728595.jpgImageUploadedByTapatalk1444188210.078374.jpg
10-07-2015, 08:22 AM #8
Sorry about the crappy photos.
10-07-2015, 09:26 AM #9
Wow, you put a lot of work into it, make sure and post up when you get it mounted!
2006 Supra 20 - Sold
2015 Supra SE450 - Sold
10-07-2015, 05:45 PM #10
Actually I cut it down today. It was too big and bulky. I also pulled the broken 1/8" drill bit and tapped the hole. Now I don't need the 2 extra holes I made. I just can't sleep when things go wrong! ImageUploadedByTapatalk1444254278.215895.jpg
