Results 1 to 8 of 8
    Jun 2015
    Montreal, Canada
    Default Boatmate trailer - tire pressure
    Hi,
    I have the single axis Boatmater trailer for my LSV.
    I was looking for the proper tire pressure on the tires however what I see on the tire wall is a mx pressure of 65 psi.
    Where can I find the proper normal pressure I should inflate the tires to.
    Mart
    May 2010
    Salt Lake City, Utah
    From everything i have read over the years, you should keep the tires inflated to close to the max psi. You can google it and i believe that is the general consensus.
    Scott
    2021 Craz
    1997 Sea Ray 190
    Sep 2009
    Tryon NC
    I keep mine at 60 psi
    Sent from my SM-G730V using Tapatalk
    "You spend most of your life, looking for the adult that you are... then you spend the rest of your life looking for the child that you were."
    98 boomerang sold
    04 outback lsv
    Aug 2015
    I keep mine at 60 psi as well.
    Oct 2015
    I have a dual axle boatmate, and the tires say max 50, so that's what I set them at. Of course, this was after having them at 40 psi since I bought the boat in February this year. I finally decided to google it, and the concensus is to run them at the max pressure.
    Jun 2015
    Montreal, Canada
    Thank you for the quick replies.
    60 psi it will be!
    Jan 2013
    Northeast, PA
    I keep mine at 60 as well
    Sent from my SM-G920V using Tapatalk
    2007 Moomba Outback V
    Aug 2015
    As a side note, read your tire wall and make sure you aren't exceeding the max psi (I doubt you are, but always worth double checking)
