Results 1 to 10 of 13
Thread: Small tree issue...
09-17-2015, 09:14 AM #1
Small tree issue...
Got to our place on the lake last night and found a "present" -- must have had a big storm and the huge sycamore tree in our yard dropped a decent size limb right on the trailer. Dented both fenders and took out some of the brake lines.
Anyone know if Boatmate sells the painted brake lines that would match the trailer?
Thankfully the boat wasn't on the trailer or that could have been real bad news!!
IMG_1880.jpgIMG_1881.jpgIMG_1882.jpgIMG_1883.jpgIMG_1884.jpgMike
2013 Outback V
- FAE
- DIY suckgate
09-17-2015, 11:24 AM #2
lucky the boat wasn't on there , could have been disastrous! Good luck getting everything put back together
Scott
2021 Craz
1997 Sea Ray 190
09-17-2015, 01:37 PM #3Senior Member
- May 2014
- Hoover, Al
- 588
09-17-2015, 02:00 PM #4
I had someone run into my fender at a boat launch and left and I ended up with an insurance claim as it was expensive to fix. A fender is hard to make true again. At the look of the tree it appears to have been dead for a while. If that tree comes from someone elses property they need to come pick it up and hand them the estimate. If it is your tree then you may want to do some trimming.
1998 Mobius
310 HP PCM
SOLD
09-17-2015, 03:21 PM #5
Homeowners insurance claim?
2015 Mobius LSV Surf Edition
6.2L Raptor power
1100's and Flow
Acme 1847
2003 Wakesetter xTi - sold
09-17-2015, 05:10 PM #6Senior Member
- Oct 2004
- Middle TN
- 148
You can get a painted fender, not sure of the brake lines.
09-18-2015, 09:21 AM #7Senior Member
- May 2014
- Hoover, Al
- 588
Small tree issue...
And a fender is cheap. I paid 273 for a boat mate painted fender with rubber pad on top shipped to my house. Just make sure you have your trailer vin when you call , Google boat are parts and give them a call. Jim is the guy that will answer or return your call, he is very helpful. Btw, the fender should just bolt on.
09-18-2015, 04:33 PM #8
Those are welded fenders like what I have so I had my fender that was damaged remolded and repainted. Hardly any automotive body shop will touch a trailer so I was lucky not to have a fender replaced. They also did the work with the boat on the trailer otherwise I would have paid for a slip while the trailer was being worked on. This trailer is worse than what I had and it still cost $1,500 to fix. The insurance comp was $50 deductible so it worked out well.
1998 Mobius
310 HP PCM
SOLD
09-18-2015, 08:56 PM #9Senior Member
- Oct 2004
- Middle TN
- 148
Pretty sure they are bolt on fenders so it should be plug and play.
09-18-2015, 09:52 PM #10
They are bolt on.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
