Results 1 to 3 of 3
Thread: cooling water intake
06-20-2006, 12:46 AM #1Junior Member
- Jun 2006
- 20
Got my 05 lsv out in some pretty dirty water over the weekend and was wandering if there was anything I should check on the water intake system to make sure no debris got sucked into engine or anything I should clean or flush out to prevent any future problems. Will not be going back to this area again.
Thanks in advance for any input on this
06-20-2006, 11:20 AM #2Senior Member
- Sep 2002
- Pennsylvania
- 106
Replying to Topic 'cooling water intake'
Hopefully you have a intake strainer? (Check it for debris). Typically you will find your engine temp running higher then normal or fluctuating if you have a restriction.
For what it’s worth, I flush the motor after each use. If you trailer you can use a Fake-A-Lake, or a Flush-Pro if you keep it docked.
Regards, E
06-27-2006, 12:45 AM #3Brian Raymond Guest
The water strainer is a plus. If you are in shallow waters or highly littered areas w/o one, remove the hose on the inlet side of the trans. cooler and feel for debis before hitting the ramp. Brian Raymond.
fresh water cooling system for sale
By Kent and Carol in forum Moomba ClassifiedsReplies: 0Last Post: 07-01-2004, 10:49 AM -
Excess Water Intake
By MNFatSack in forum Service & RepairReplies: 7Last Post: 05-29-2004, 04:48 PM -
Fresh Water Cooling
By Kent and Carol in forum Moomba ClassifiedsReplies: 0Last Post: 03-02-2004, 04:08 PM -
By Kent and Carol in forum Moomba ClassifiedsReplies: 0Last Post: 02-09-2004, 07:01 PM -
By Kent and Carol in forum Moomba ClassifiedsReplies: 0Last Post: 02-09-2004, 06:55 PM
