Results 1 to 10 of 14
    Apr 2013
    Dallas, TX
    Default Dual filling ballast bag
    I've updated the left ballast bag on my 2013 LSV to 1,000#. It takes around 10.5 minutes to fill and empty. No one in my family surfs goofy, so I was thinking about rerouting the right pump to fill the left bag. The larger bag has 2 connections on top. Are there any potential issues having my two pumps filling the 1,000# bag simultaneously? It would cut the fill time in half. Where can I get the hose and clamps to do this since I'll have to extend the length. Could install a "T" connection to fill both sides.
    ADM
    2018 Craz
    Des Moines, IA
    Interesting idea. I'd also want a larger vent if it were my boat. With reversibles you'd want both fill/drain ports to be on the bottom of the bag, and I wouldn't use a T connection or you'll be losing a lot/all of the fill potential. Good luck and post pics!
    Nov 2003
    Land O Lakes, Florida
    no reason you could not do something like that
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Mar 2015
    Brighton, MI
    For the Echo Skis budget build we contaplating double filling the rear bag. So long as you have enough ports on your bag it should work. I can't see any reason it won't, let us know how it works if you do it.
    Apr 2013
    Knoxville TN
    I agree.
    You can find the fittings around the net depending on the sizes of the hose/ballast connectors and fittings.
    When I upgraded my Supra, I used WakeMakers: http://www.wakemakers.com/
    Easy to use and deal with.
    You may be able to fill with 2 pumps (bottom and top fittings), but you will only be able to drain from the bottom connection.
    Unless your bag has 2 fittings on the bottom.
    I assume your bag currently fills and drains from the bottom fitting and one of the top fittings is the vent.
    On my 2007 Supra, I have 3 Johnson Pumps. Two are on the back bags (750#) - right and left.
    I have the other pump that is connected to the Center Bag and Bow Bag for wake boarding.
    I have a Y-Valve that controls what bag it fills or drains. Works well.
    Pump > Y-Valve > Hoses to each Bag
    I made sure all of my bags are vented.
    http://www.wakemakers.com/bosworth-y-valve.html
    Overall, 10.5 mins is not bad . . . drink a beer.
    I'm usually connecting the surf ropes or getting the vests ready to use.
    So as I'm moving around the boat, once I see the water coming out of the vent on the side of the boat, I'm good to go.
    If you can connect 2 pumps to one bag, 5 mins to fill/drain, let the group know how it works
    M-
    May 2013
    Fairfax, VA :(
    Wasn't Wakemakers or someone making a cross fill where you could pump from one bag to another? The idea was to pump across rather than up to make it faster? I think they were putting two fittings on the bottom which could come in handy for this. Not sure if that ever made it.
    2007 XLV Gravity Games
    1,100 in each rear locker
    1,180 in front
    Fresh Air Exhaust
    SuckG8
    Bunch of other crap
    yes, wakemakers calls it the "X-link" system
    http://www.wakemakers.com/x-link-cro...t-package.html
    Apr 2013
    Knoxville TN
    I recall reading that was the pump between the 2 back bags.
    1" line connected thru the pump.
    Something like 5 mins to switch the water in the bags.
    Still would need to have bags with 2 fittings on the bottom
    Not sure why all bags would not have extra fittings on the top and bottom.
    M-
    Jun 2009
    South West Colorado
    Actually, you don't need two fittings on the bottom of the bags. I have the x-link. What I did was put a 1" t fitting in line between the pump and port on each bag. Then plumb the x-link lines to those t fittings. Works great and I didn't need to buy new bags.
    '08 Mobius LSV- SOLD!
    2017 Mojo Pro
    May 2013
    Fairfax, VA :(
    Quote Originally Posted by moombahighrider View Post
    Well that makes sense. What is your transfer time on those bags?
    1,180 in front
    Fresh Air Exhaust
    SuckG8
    Bunch of other crap
