Results 1 to 2 of 2
Thread: Bilge pump
06-16-2006, 11:24 AM #1Member
- Jul 2004
- Lake Elmo, MN
- 81
Bilge pump
Bilge pump is not woring on 05 LSV. I have had problems in the past when it was dirty. Removed debris and it worked. This time, when I manually put it on from the dash, the switch lights up but pump does not run. Is there a fuse for the pump? If that fuse is out would the light on dash still come on? Pump is clear of debris.
Still under warranty, but the time and effort to take it to the dealer is something I would rather avoid. I'm thinking I'm better off just buying a new pump and snapping it in.
Thoughts? Will it be easy to get a replacement pump that I can just snap in without having to reattach to the floor?
06-16-2006, 12:24 PM #2
Replying to Topic 'Bilge pump'
I would recommend having the dealer send you a new pump motor and you send back the detective pump motor.
1998 Mobius
310 HP PCM
SOLD
Bilge pump
By kmcg in forum Service & RepairReplies: 2Last Post: 06-13-2007, 10:26 AM -
Bilge Pump
By wakerider in forum Service & RepairReplies: 5Last Post: 03-28-2006, 08:26 AM -
Bilge Pump Problem?
By scott016 in forum Service & RepairReplies: 13Last Post: 05-26-2005, 09:07 PM -
bilge pump
By pike1990 in forum Sales & InformationReplies: 1Last Post: 09-04-2002, 11:06 PM -
Bilge pump
By mikeoc in forum Boat OwnersReplies: 1Last Post: 07-29-2002, 07:39 AM
