Results 1 to 10 of 13
    Mar 2006
    Chapin, SC
    Default Depthfinder on DD
    I am going to be installing a Depth Finder in the bilge area of my 04 Outback DD. At first glance the transducer looks like if will fit just behind the drain plug / in front of the bilge pump. Has anyone done this or have a better location so that you get good readings? Thanks for the help.
    I mess with Texas
    Mar 2005
    t-town
    Default Replying to Topic 'Depthfinder on DD'
    The awesome Brian Raymond helped me with this one. I mounted it right under the transmission as per his instruction on my old outback and it worked great.
    hope this helps...
    db
    Feb 2006
    Fayetteville, GA
    hope this helps...
    db
    Ditto.
    The fins will cause some turbulance.
    Remove the tranny cover/floor plate.
    You will find some nice places to mount it under there.
    Be sure to sand as flat as you can, no bubbles in the epoxy, and you should be good to go.
    Apr 2003
    Powhatan, VA
    Where the prop shaft passes thru the floor there may be a single wall area of hull that will accomodate the sensor.
    Mar 2006
    Chapin, SC
    Thanks everyone, tested it out this weekend with tape and it works great at all speeds. Shall silicone or expoxy today.
    I mess with Texas
    May 2006
    Nashville
    YM:
    Thanks for posting this question. I'm also mounting a transducer on my '05 Mobius.
    The instructions on my sounder recommend epoxy and advise against silicone - states it will decrease accuracy. They even say 5 min epoxy is bad, due to failure to purge bubbles prior to curing. Not sure how much difference it will make.
    Sure would be nice if silicone works - I'd rather use that myself. Anyone else use silicone with success? Also curious if it's possible to use resin with a release agent, so the transducer could be relocated or replaced if needed.
    Jim
    Mar 2006
    Chapin, SC
    Thats exactly why I wanted to use silicone. I cannot get mine placed well enough behind the transmission to give me a reading that I can truly test. Currently I have it trapped under the steering cable. Consider the bilge plug 6:00 and the Ski pylon plate 12:00. Mine is sitting at 9:00-ish and if I pour a solo cup of water in the bilge it works perfect at all speeds. It definately did not work sitting on the pylon plate because of the skegs.
    I talked with Mark at PCM on the lake this weekend and he has his attached with silicone in his 93 sport nautique in the same area we are talking about. I suppose I will re-read my instruction booklet regarding do's and dont's before I make the final application.
    I mess with Texas
    Mar 2003
    Springfield Missouri
    Silicone always worked for me and I've never had one come off.
    1998 Mobius
    310 HP PCM
    SOLD
    May 2006
    Nashville
    It's worth a try with silicone, I guess. It's easy enough to fix if the results are bad. Seems the trick would be to press out as much silicone as possible from under the unit.
    I killed my prop 15 hours into Moomba ownership. Hit a ^%*$#$ cinder block 70 feet offshore.
    The only time I'll look at this gauge is when cruising in and out of lake runs when going 5mph, but still want it to work correctly. We camp a lot, so have more need for moving close to the beach.
    Next angler I see throwing a cinder block into the lake might get more than he bargained for depending on what kind of mood I'm in.
    Jim
    Dec 2005
    Ontario
    Oh wow man that sux....wtf are people throwing cinder blocks in for?? anchoring?
    2005 Moomba Outback
  1. depthfinder memory lost when ignition off
    By mvd in forum Service & Repair
    Last Post: 04-11-2007, 03:51 PM
