Results 1 to 8 of 8
Thread: Moomba Cooler issues
07-31-2015, 10:46 PM #1Senior Member
- Jan 2014
- Kelowna, BC Canada
- 426
Over the past few weeks our Moomba cooler hasn't been keeping ice like it used to. Within a few hours all of the ice is melted. Before you could keep a bag of ice ALL day without an issue at all. It is also leaking water out of the bottom of it.
So I opened it up and the bottom has multiple tears in the grey plastic liner. We have only had this cooler since July of last summer and already it needs to be replaced.
Anyone else have this issue? We never put anything sharp in it ... cans only ... so I'm not sure where the tears are coming from.
When I first saw what we got for the $100 option I wasn't impressed at all ... but then I saw the cooler work and it was totally worth it. Now its garbage.2014 Black/White Mojo
345HP Surf Motor
1235 Prop
Autoflow 2.0 Upgrade
1100# FlyHigh Rears
650# IBS
4 x Exile SXT9q's w/ Exile 30.2 amp and Exile ZLD controller
Exile Javelin Amp
10" Rockford sub
07-31-2015, 11:25 PM #2
Ours did the same thing, it not resides in the Attic.
You could just put another bag inside the cooler, I know this isn't ideal but it is what it is.
The reason it doesn't keep things cool is because all the cold water leaks out. This happened the second or 3rd use of the cooler.
We now use soft sided collapsible coolers we got at Costco.
We use 2 of these, I put a 30 pack of brew and 16lbs of ice in it and it lasts all day, including reloading beer through it.
The other we stack water, soda food in.
http://www.amazon.com/Arctic-Zone-Ul.../dp/B00XKBI5DU
http://offroadpassport.com/forum/showthread.php?t=1847Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
08-01-2015, 10:27 AM #3
Mine did the same, we now have the soft side Yeti and it is fantastic.... Keeps I e far better than the Moomba cooler plus it does not leak.. Greatest cooler for the boat!!!
KRiley
2013 Moomba LSV
Exile xm9s
Exile Amps
Exile sub
08-01-2015, 10:33 AM #4Senior Member
- Jan 2015
- Live: OP, KS...Boat: Shell Knob, MO
- 167
Mmandley, do both of those coolers you use fit under the Mojo seats?
Sent from my iPad using Tapatalk2013 Mojo
08-01-2015, 07:29 PM #5Senior Member
- Jan 2014
- 426
Thanks guys will look into both options ... for anyone else thinking of adding the $100 cooler option to your Moomba don't bother. It's a POS.
345HP Surf Motor
1235 Prop
1100# FlyHigh Rears
650# IBS
Exile Javelin Amp
10" Rockford sub
08-01-2015, 09:02 PM #6Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
08-01-2015, 11:23 PM #7
08-02-2015, 07:58 AM #8
Our cooler of choice, besides the Coleman stackable that fits under the open area in the xlv.
http://www.target.com/p/igloo-maxcol...FdCRHwodNkcDYgA Day at the Lake...Priceless
