Results 11 to 12 of 12
09-01-2015, 01:59 PM #11Senior Member
- May 2014
- Hoover, Al
- 588
Selling 3 pair stock Kicker speakers from the 13 Mojo.
09-01-2015, 06:16 PM #12I was just not sure that the kickers would have held up to the rms I was going to run through them
I see no derogatory remarks here about any brand or model, just wanted to the member posing the question about the upgrade, to take the answer with a footnote attached. When a speaker is swapped, there is certainly a change in how the system sounds, as there should be. This can be fair comparison because the test parameters stayed the same. But if there is an upgrade to the speaker wattage at the same time, then the change is sound is a result of a 2 stage upgrade. The new sound is now based on both a driver and amp change, rather then just a driver change. Kinda like surfing with 400 lb sac then upgrading to an 1100 and also adding Flow and seeing a huge improvement. If someone else just added the 1100 or just the Flow, they may not have the same results.
