Results 1 to 10 of 16
Thread: Tongue weight?
07-22-2015, 11:36 PM #1
Tongue weight?
Can someone with a LSV, XLV, or Mojo tell me what their tongue weight is? Not a wild guess please.
Trying to figure out the weight limits and cargo capacity of a tow vehicle.
Gracias.So when is this "old enough to know better" supposed to kick in?
07-23-2015, 12:11 AM #2
Heh heh. There's a joke there somewhere but I'll leave it alone this time.
07-23-2015, 12:19 AM #3
To get an accurate number, you need to weigh yourself and then weigh yourself holding the tongue up. lol
1998 Mobius
310 HP PCM
SOLD
07-23-2015, 05:26 AM #4
You can use a bathroom scale and a four foot long 4X4 post. Lay one end of the post on the scale. Place a block under the 4X4 three feet away from the scale. Zero out the scale. Set the tongue on the 4X4 two feet away from the scale. Multiply the scale reading by three. That will be your tongue weight.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
07-23-2015, 07:39 AM #5
The method above works well. If you don't have the boat, you can take 10-15% of the combined boat & trailer weight as a good approximation. I want to say that my '15 Mojo is about 600 lbs.
Sent from my SM-G900V using Tapatalk2015 Mojo
07-23-2015, 10:10 AM #6
if you are concerned about tongue weight because of the tow vehicle limitations consider a different tow vehicle. Just saying
2017 Centurion Ri237
2013 Supra SA450 - Sold
2006 Mobius LSV - Sold
2004 Stingray 190LS - Sold
07-23-2015, 11:20 PM #7
Exactly.
I know for a Fact the Mojo is a heavy nosed girl.
on my 1 Ton F350 she squatted the rear 3 inches. Had to get Air Bags to level out
On my 13 F150 she squatted the rear 4 inches. Even with 100lb Air bags if I added anything more then the boat she squated.
On my Current 3/4 Ton Ram she squats it about 3 inches, until the truck self levels.
I'm guessing the tongue weight is 600-700lbs. Big Wide nose, and it sits really fare up on the trailer compared to most boats.
Monday I go to WTW and I pass a scale, Ill put my rear axle on it then disconnect the boat real fast and see what it weighs with out the boat connected. Maybe that will help more.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
07-24-2015, 12:08 PM #8Senior Member
- Feb 2005
- Ottawa, Ontario, Canada
- 718
525 lbs for my XLV. It makes my Ridgeline squat 2.25" at the rear axle. I originally used a Class III Reese ball mount (rated for 500 lbs), but a friend watching from further away saw it bending under load! Then I weighed it. Since there were no marginally better Class III mounts available locally, I switched to a Class IV mount.
2005 XLV, upgraded ballast, Comptech swivel wakeboard and hydrofoil racks, Monster cargo bimini
07-24-2015, 01:34 PM #9Senior Member
- May 2014
- Hoover, Al
- 588
07-24-2015, 02:24 PM #10Senior Member
- Jul 2015
- Northeast WI
- 207
I agree with the above, assuming the trailer is level with the road.
