Results 1 to 2 of 2
Thread: Ballast Plumbing
06-11-2006, 09:12 PM #1Senior Member
- Aug 2005
- 134
Ballast Plumbing
At the engine there are 2 or 3 pumps and a filter for the ballast bags that feed off this 12-15 inch plastic pipe that is bolted in . The pumps screw off easily. The weight of one pump cracked the plastic right where you turn the screw to tighten it. I tried some plumbers epoxy and supported the pump with a wire but it is still dripping a little when I go over 10MPH-I guess the water pressure builds up and a little water runs through. I cant turn the pumps on because water starts spraying all over. Where can I get this odd piece of plumbing???? It doesnt look that hard to put a new one in and reconnect the pumps and filter for the ballast. Does anyone else get a little drip from these pipe.?The bilge is right under it so it will empty but its dripping on the v-drive case or whatever you call that thing.
06-12-2006, 08:48 PM #2Senior Member
- Aug 2005
- 134
I got it
I dug in there today and pulled the pumps off and strainer. At least now I see how its put together so I can winterize it myself without dealing with the prick at the marina. I think he broke it because last year it was fine. Anyway, you dont have to waste a post.
Plumbing outback LS ballast
By clowninmd in forum Wakeboarding | WakeskatingReplies: 4Last Post: 08-22-2019, 03:48 PM -
Outback LS - plumbing in factory tank
By stuey in forum Wakeboarding | WakeskatingReplies: 5Last Post: 04-21-2008, 10:32 AM -
Plumbing?
By byronkoz in forum General ChatReplies: 2Last Post: 02-08-2008, 09:35 PM -
plumbing ballast under front seats?
By sickmobV in forum Wakeboarding | WakeskatingReplies: 1Last Post: 09-21-2006, 11:03 AM -
Ballast Plumbing Supplies
By AL02REDMOBLSV in forum General ChatReplies: 0Last Post: 02-03-2006, 04:31 PM
