Results 1 to 7 of 7
    May 2015
    NC
    Default Perfect Pass Power Wire
    My perfect pass power and ground wires go to my tach. Can I just move the ground to a ground on the panel? Do I run the purple power wire to the ignition terminal that has a purple wire going to it?
    Could this be causing my dash lights to stay on?
    2003 Mobius LSV GG Edition - Sold!
    May 2015
    NC
    May 2015
    NC
    Thought I would add this. I unplugged the power wire from the master module, I gained almost 2 full volts (per the gauge) from doing this!
    Now my speedo isnt working. Could unplugging the master module and gauge do this? I have unplugged the PP gauge before and the speedo still worked. So im confused unless the module is wired to the speedo somehow.
    May 2013
    Vancouver WA
    often on these boats, they daisy chain the power and ground wires for the instrument cluster. on my last boat, the PP would have issues because of low voltage. I ran a new circuit for that and ran a good ground to under the helm with a bus bar. Everything improved with better power and ground...
    www.TraysonsToybox.com
    May 2013
    Did you find a cleaner 12 volt circuit under the helm or did you run one back to a battery.
    May 2013
    Vancouver WA
    Quote Originally Posted by cornrickey View Post
    on my 92 sunsport, I ran a new one.
    May 2015
    NC
    I plan to hook the power wire into the ignition and run the ground back to the battery. I guess it would make sense to do a bus bar so if I decide to add any other electronics.
    After reading some threads today, I really want to inspect my engine ground connection point. I feel like it could be cleaned up and that would help some of my voltage issues.
