Results 1 to 6 of 6
Thread: Stereo help
06-23-2015, 11:00 PM #1
Stereo help
I have no power to head unit or amps...my first thought would be fuse. I have power to everything else as far as I know.I've had very little free time. Any idea to location or places to check or any other ideas ? I have someone scheduled to look into this issue tomorrow. Any help would be great.
08 lsv all red- dual battery system, kicker 700.5 and 450.2 amp, 10" kicker sub, wetsounds eq, polk db651 cabin speakers, exile xm7 tower speakers, ss thru hull fittings, seadek pad, evolutions cover
https://forum.moomba.com/showthread.php?t=10664
06-23-2015, 11:12 PM #2
When you say no power, do you mean that the head-unit will not come on or you have taken a volt meter to the head-unit and amps there is no battery B+? From the factory, the amp(s) and head-unit would each have their own circuit protection, whether its a fuse or breaker. Also, the head-unit needs a switched turn-on 12V trigger on the red lead. Amps will not wake up until the head-unit turns on.
Is the system was installed aftermarket, things could be different. Have you checked the battery levels with a meter?
06-23-2015, 11:28 PM #3
I've pieced my system together over my first few years and was installed professionally. I have an on bank charger I keep on the batteries but haven't put a tester on them. No power at all at headunit. Dual battery system as well
06-23-2015, 11:29 PM #4
Headunit won't power on at all
06-24-2015, 07:46 AM #5
Theres 3 circuits at the back of the head-unit that would prevent it from turning on. Amps wont wake up until head-unit does.
06-26-2015, 08:30 PM #6
Replaced head unit and tunes are back! Thanks
