Results 1 to 10 of 17
Thread: Center Drain Plug
06-09-2015, 09:14 AM #1
Center Drain Plug
While performing my ballast upgrade a noticed a spot on the bottom of my boat between two of the tracking fins that was a flattened out circle like it was meant to have a center drain plug installed there. If you remove the floor from inside there is a hole
Molded into the gas tank that I believe goes to where this circle is. Has anyone added a center bilge drain to their boats?? I am considering doing this on my 08 LSV but am not sure how. I know shortly after my model year they started to come standard with the center drain plug.
Sent from my iPhoneDavid
06-09-2015, 09:55 AM #2
Need to find a kit like this one but with a flat plug:
http://www.nueratrailerparts.com/p-1...FdgQgQodDQsAkgMy Mom said I'm not allowed to get wet!
06-09-2015, 09:57 AM #3
Center Drain Plus
Well all the new boas have the plug that you remove or install from inside the boat. I was hoping to find one like that. I don't think it would be too hard to drill a hole in the floor and install an access panel like the newer LSVs
06-29-2015, 06:31 PM #4
I believe the problem is the gas tanks weren't molded with access to the area where the plug would go. You'll have to access it from underneath the boat. The kit like Pat posted will work fine. I wouldn't worry about the plug being exposed as it's inline with the tracking fins and doubt it'll create much if any drag. Be careful when drilling from bottom up as gas tank sits above with maybe 1/2" of clearance.
2008 Mobius LSV
1100#er's in the lockers
ski locker sac
IBS
Johnson reversibles
06-29-2015, 06:55 PM #5
06-30-2015, 08:38 AM #6
Center Drain Plus
I have a hole in my gas tank that looks like it goes down right where the plug would go. I'll test it with some magnets in the next week
07-18-2015, 04:12 PM #7Junior Member
- May 2010
- Western Washington
- 8
Center Drain Plus
Did the holes line up? I have a 2003 Outback LSV, I have the same water not draining problem and the molded area behind the first track fin. I also have a hole in the fuel tank but have not taken the time to see where it lines up.
I was thinking of using a Garboards with a backer so I would have no concern for the attachment to the boat. Anyone have an opinion on theses vs the standard wood screw style?
Sent from my iPad using Tapatalk HD2003 OUTBACK LSV
07-25-2015, 08:48 PM #8
Any info on this? Would love to do this if the holes line up.
Scott
2021 Craz
1997 Sea Ray 190
07-25-2015, 10:22 PM #9
I have not had a chance to look into it yet. I wish I didnt spell plug wrong in the thread title though. embarrassing!
07-25-2015, 11:10 PM #10
