Results 1 to 6 of 6
Thread: Ballast fill trouble?
06-05-2006, 12:16 AM #1Senior Member
- Mar 2004
- Wylie, Tx.
- 212
I have a new 06 XLV and I noticed that everytime I want to fill the ballast bags. I have to go to the back and remove the hoses and prime the pumps. It looks like there is an airbubble that is in the screen filter that makes the pumps cavitate. Once I mess with them some I get water going and then I pop the hoses back on. Anyone having the same issues and if so what are you doing that I'm not. I plane the boat out as well and this still doesn't fix it.
MedicMedic151
06 Mobius XLV
06-05-2006, 02:01 AM #2Senior Member
- Jul 2003
- 340
Replying to Topic 'Ballast fill trouble?'
Might want to check the fill pump itself. Could be that it sucked something up that partially damaged the impeller keeping it from priming on it's own. Once it gets primed it may still work but only at a reduced capacity.
06-05-2006, 04:55 AM #3Guest
everytime you pull the boat in and out of the water it is going to loose prime naturally. After you leave the no wake zone turn on ballast pumps and accellearate forward, then stop abrubtly so that water slams into the back of the boat. Try this a couple of time and it will prime your hoses.
-KJ
06-05-2006, 06:57 AM #4Junior Member
- Apr 2006
- 2
The boat naturally looses prime when you take it in and out of the water. After re-entering water and leaving no wake zone, turn on ballast bags and try accellearting and stopping quickly to allow water to push up into the intake. Do this a couple of times and your bags should start filling up.
06-05-2006, 08:51 AM #5Senior Member
- Mar 2004
- Wylie, Tx.
- 212
Thanks. I will give that a try.
MedicMedic151
06 Mobius XLV
06-05-2006, 10:36 PM #6Junior Member
- Jun 2006
- 1
I had the same problem
Accelerate to 25-30 MPH then rapidly turn your ballast pumps on and off (about 10-15 times). This forces out any air pockets in the line, and has worked for me every time. Beats unhooking the lines.
Please fill this out!
By Miller_Time in forum General ChatReplies: 0Last Post: 03-25-2008, 05:51 PM -
Has anyone upgraded their ballast fill pump?
By cab13367 in forum General ChatReplies: 0Last Post: 08-08-2007, 04:32 PM -
ballast fill w/ air
By J-Lawv in forum General ChatReplies: 1Last Post: 08-02-2004, 05:50 PM -
ballast fill w/ air
By J-Lawv in forum General ChatReplies: 0Last Post: 08-01-2004, 10:55 PM -
posting trouble
By james yarosz in forum General ChatReplies: 1Last Post: 04-14-2004, 12:58 AM
