Results 1 to 3 of 3
Thread: Oil Change
06-03-2006, 11:11 AM #1Junior Member
- Dec 2005
- 9
Oil Change
Do you really need to heat the oil up by running eninge prior to oil change? What purpose does that serve other than to heat oil to run out quicker?
06-03-2006, 11:42 AM #2Senior Member
- Apr 2003
- Powhatan, VA
- 316
Replying to Topic 'Oil Change'
No, not necessary at all, but makes the process quicker because the viscosity of the spec oil is relatively high at ambient temp.
If shirtsleeve weather, and engine not run recently, I estimate it takes 90 minutes for mine to drain to a slow drip.
Actually, its much easier not hot, especially to get the filter off cleanly without burning your arm.
06-04-2006, 01:35 PM #3
Most of the time when you run an engine and get it warm it is to make sure there is no sludge or moisture in the engine not just to speed up the process. New engine or old you can still get moisture in it, and sludge will be thinner and flow out warming engine is the way to go IMO.
ScottShare The Water
2006 Outback V
Similar Threads
Oil Change
By ajmoritz17 in forum Service & RepairReplies: 5Last Post: 04-30-2008, 09:23 AM -
1st oil change
By doug0446 in forum Service & RepairReplies: 11Last Post: 06-21-2005, 11:52 AM -
oil change
By michelle in forum Service & RepairReplies: 2Last Post: 09-22-2004, 12:53 PM -
oil change
By Keaton in forum Boat OwnersReplies: 0Last Post: 04-05-2004, 10:00 PM -
Oil Change and Impeller Change
By MartyC in forum Service & RepairReplies: 2Last Post: 03-14-2004, 10:22 PM
