Results 1 to 10 of 10
Thread: Fittings stuck in bags
06-01-2015, 03:33 PM #1
I bought some 650 lb bags from a buddy go upgraded to 1100s in his mojo and I need to replaced the 1" vent connection with a 3/4" one. I cannot get the stock 1" connection out of the bag. It appears that they glued them in??? How do you get these off????
Sent from my iPhoneDavid
06-01-2015, 04:10 PM #2
https://www.youtube.com/watch?v=qpW_x9MeAQo
works pretty good. I think I used the hair dryer for like 10 min or so to soften the glue. On a few of mine after I put the new fitting in I would get a little water leaking from the new fitting. Wakemakers said to get some PVC pipe glue. You need the kind that comes in a two part system (primer and glue) and only use the glue, NOT the primer. I've used it and it worked great.Scott
2021 Craz
1997 Sea Ray 190
06-01-2015, 06:47 PM #3
Doesn't work with flip flops!
-Jake
06-01-2015, 06:57 PM #4
or bare feet, too hot!
Scott
2021 Craz
1997 Sea Ray 190
06-02-2015, 01:14 AM #5
It does not work nearly as easily as they make it look in the video but I got them out
06-04-2015, 08:54 AM #6
2008 Moomba Outback DD resurrection
06-04-2015, 10:33 AM #7
Those fittings don't come out till you get angry enough to destroy the bag if necessary-- then presto! They come out.
06-04-2015, 10:50 PM #8
06-05-2015, 01:00 AM #9
I had the hair dryer on there for 15 minutes and it was not "presto". It was a little more how Kaneboats described it. I was worried I was about to rip the black piece out of the bag
06-05-2015, 01:18 AM #10Junior Member
- Oct 2013
- 21
Mine was 20min with a hair dryer and then a set of plyers destroyed the fitting, kinda damage the the bag threads a little pvc cement works like a charm
