Results 1 to 8 of 8
05-31-2015, 10:10 PM #1Senior Member
- Oct 2013
- 135
bluetooth on stock sony head unit
so i picked up the exile audio bluetooth receiver in hopes of just plugging it into my stock head unit for this summer till i get an zld as i would rather spend time on the lake than wire it in. there is i input on the back of the head unit that is labeled "bus in" is that where a guy would plug that in or is that head unit not compatible of supporting something like that.
2013 outbackv
06-01-2015, 11:32 AM #2
I believe buss in is for the Unilink that Sony Decks use. This is data and not AUX input for audio. You should use the BT with either an deck that accepts aux inputs or into a preamp EQ like the ZLD or if it is a single amp setup-plug directly into the amplifier itself. -Brian
06-01-2015, 01:57 PM #3
would this work and just plug into the usb port on the sony, front or rear
http://www.ebay.com/itm/like/3217507...lpid=82&chn=psA Day at the Lake...Priceless
06-01-2015, 06:05 PM #4
Actually the RCA is strictly audio and no data. Only the multi-pin Unilink DIN is data. However, you typically cannot open that RCA input port without Unilink. If the Sony HU is older without the USB options then you can likely use a Sony XAC40 to open the audio port with 'Aux' now showing in the Sony menu. But, the cost of the XAC40 is more than a Clarion EQ and halfway to a ZLD so you have to justify the expense for a short term solution if you are planning to get an EQ anyway.
06-03-2015, 12:25 AM #5Senior Member
- Oct 2013
- 135
thanks guys it sounds like a bluetooth free sumer unless i find the motivation to slam a zld in during the week
2013 outbackv
06-03-2015, 12:29 AM #6
does the head-unit not have front 3.5mm AUX input? Less than ideal, but doable short term.
06-03-2015, 09:06 AM #7
06-03-2015, 09:37 AM #8
this would work
http://www.amazon.com/Hosa-Cable-YRA...F8+to+male+rcaA Day at the Lake...Priceless
