Results 1 to 2 of 2
Thread: Boat Lift
06-02-2006, 01:20 PM #1Junior Member
- Apr 2006
- Fargo, ND / Lake Lida
- 12
Boat Lift
I just bought an older Shorestation lift for my Outback. It does have two bunks that run the length of the lift, but I am not sure what else I need to make sure it is setup for an inboard. Can anyone help me out with exactly what I need?
Thanks.
06-04-2006, 11:44 PM #2
Replying to Topic 'Boat Lift'
Obvious - make sure your lift allows you to load the boat without interferring with the drive shaft, prop, or rudder.
Not so obvious - if you have a cabl running across the front of the cradle make sure it does not rub on the keel.If you believe something to be true, it will be - in it's consequences.
Boat Lift
By OldeBoy in forum General ChatReplies: 9Last Post: 06-04-2008, 11:05 PM -
boat lift
By liquidlite in forum General ChatReplies: 0Last Post: 02-17-2008, 11:36 PM -
Boat Lift
By NateDog in forum General ChatReplies: 2Last Post: 07-31-2007, 11:22 AM -
Boat Lift
By jwest2000 in forum Service & RepairReplies: 10Last Post: 04-21-2006, 01:27 PM -
Advice needed: boat winch vs. boat lift
By Rock Laubster in forum General ChatReplies: 2Last Post: 04-17-2006, 09:20 PM
