Results 11 to 20 of 60
Thread: Reversible Pump Upgrade
05-25-2015, 09:02 PM #11
How do you get the ball valves tight on the thru hull without have the thru hull tight to the hull? Or does that 5200 stuff dry hard? And I'm adding three new thru hulls, one for each v-drive bag and one for the IBS. The original through hull is going to only operate the center 400 bag. Also what size wire did you run to the distribution block?
Sent from my iPhoneDavid
05-25-2015, 09:12 PM #12Senior Member
- Aug 2011
- 2,522
Re: Reversible Pump Upgrade
I let it cure, then use a pipe wrench to hold the thru hull and pipe dope.
Don't get me wrong, you want to get the thru hull tight. A large chisel or screw driver from underneath and a adjustable wrench. I use a pipe wrench to hold the thru hull in place and tighten the but from the inside since I'm helper less..
When it's wet no matter how tight you get it it'll move until it dries..http://www.instgram.com/jlyons30
2002 Moomba Mobius LSV - Sold
2006 Moomba Mobius LSV - Sold
05-25-2015, 09:14 PM #13Senior Member
- Aug 2011
- 2,522
I think 8 gauge, also you want the breaker fuses instead of regular fuses. They reset..
05-25-2015, 09:24 PM #14Senior Member
- Aug 2011
- 2,522
05-25-2015, 09:46 PM #15
05-26-2015, 11:26 AM #16
One trick that's REALLY handy is to take the handle of the ball valve and cut it in about 1/2 so it can actuate either up or down. Just a 3" cutoff wheel is what I used.
Doing the thru hulls for reversible is easy. the aerators are way harder as you have to be able to twist a pump on it and still have everything aligned with the output of the pump.
Pro-tip from Berg: the handle of a large crescent wrench fits in the thru hull from the bottom and will hold it in place while you crank on the nut or the ball valve.
Also, if you're planning on using your factory pump for one of your existing bags, you're going to have to install a vented loop or the 1 aerator pump will most certainly fill passively. Remember, you're removing the sprinkler valve from the mix and that's what kept your system from filling. In fact, it still might passively fill while underway because you have the scupper intake for your OEM. You might give some thought to using the factory scupper intake for your smallest bag that's plumbed to the reversible. those pumps in theory won't let water in despite having the scupper intake. I have a reversible on mine.2008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
www.TraysonsToybox.com
05-26-2015, 11:31 AM #17
Oh, another thought.
When I did my reversible pump, I got the two extra check valves and the TEE so that I could do the above water line draining. I really like to be able to watch and know when my pumps are done rather than have to open storage compartments or listen for the change in frequency as the pump gets finished. With 3 pumps if you have them all near each other, hearing when one is done and the other two are still going could be challenging.
I have separate thru-hulls for the vent and drain on my bags. I'm not shy about drilling holes and it's cheaper to buy another thru-hull than to buy a tee and another check valve to combine the vent with the empty.
05-26-2015, 02:30 PM #18
I plan on leaving one sprinkler valve in the boat for the center bag to prevent exactly what you just described. Basically I'm going to have the factory gravity 1 set up plus three reversible pumps, one for each v drive bag and one for the IBS. The main thing I am curious about is where to mount the pumps. I saw Parrothd had his mounted above the transmission but his boat looks like an older model than mine. Also seems like a good idea to mount the impeller side of the pump towards the bottom to prevent a water leak falling on the actual electrical pump however this would make it more difficult to change impellers in a pinch
05-26-2015, 02:38 PM #19Senior Member
- Aug 2011
- 2,522
Same boat.. Just older pic
05-26-2015, 02:39 PM #20
The instructions say: "however, it is
suggested that the pump head be down if
vertical mounting is desired."
If I was keeping the sprinkler valve setup as you described, I'd spend the money and get the Irritrol high flow sprinkler valve to eliminate/lessen that bottleneck.
https://www.dripdepot.com/product/54...H8XxoCaavw_wcB
the 1" ones are pretty spendy, but the 3/4 are reasonable. Optimally it'd be great to swap out to 1" line and the high flow sprinkler valve for the gravity 1 retrofit... But the price jump on the 1" sprinkler valve might be a deterrent.
I used 3/4" hose for my reversible because I only have it filling a 400 bag most the time. so despite the fact that the reversible and the 3/4 are slower, it works out okay since it's a smaller bag.2008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
