Results 1 to 10 of 60
Thread: Reversible Pump Upgrade
05-25-2015, 11:43 AM #1
Ok so my wife bought me the reversible pump upgrade kit to replace the factory sprinkler valve set up in our 08 LSV. My plan is to use the three reversible pumps to fill the v drive locker bags and the integrated bow sack and keep the original pump set up for the ski locker bag. I was wondering if those of you who have done this can provide pictures of where you drilled the new thru hulls and where you mounted the pumps ect. Also any pointers would be much appreciated. I am going to put an order into wakemakers this week for some extra pieces that the kit did not come with so a coupon code would also be awesome. Thanks!
Sent from my iPhoneDavid
05-25-2015, 12:00 PM #2
this will be a project I may tackle next year, following with interest.
Here is my IBS project from this year. Need to go in and update now that the vented loop is installed and the switch is wired into the pumps.
https://forum.moomba.com/showthread....u-hull-for-IBS2017 Centurion Ri237
2013 Supra SA450 - Sold
2006 Mobius LSV - Sold
2004 Stingray 190LS - Sold
05-25-2015, 12:07 PM #3Senior Member
- Aug 2011
- 2,522
Re: Reversible Pump Upgrade
Search my username, I've got several threads with pics for the thru hulls, drivers side near the trans. Also switch locations, and installing the motors above the trans..
The link above is a aearator pump setup not a reversible..http://www.instgram.com/jlyons30
2002 Moomba Mobius LSV - Sold
2006 Moomba Mobius LSV - Sold
05-25-2015, 12:11 PM #4Senior Member
- Aug 2011
- 2,522
Order the oikler clamps for a factory looking install, get the one way vents and run the starboard vent to port and port to starboard and 1100 bags..
05-25-2015, 12:24 PM #5Senior Member
- Aug 2011
- 2,522
05-25-2015, 07:41 PM #6
How hard was it installing the through hulls??? I'm scared in gonna drill a hole and then not be able to fit a wrench on them to get them tight
05-25-2015, 07:50 PM #7
05-25-2015, 08:37 PM #8Senior Member
- Aug 2011
- 2,522
It's not the tightness that keeps water out, the 5200 does, the bolt is there to hold the fitting while the 5200 dries. Don't over tighten, all you'll do is squeeze out all of the 5200.
I use a small drill bit and drill a small pilot hole from the inside where you want to intake to be.
I put the valves and thru holes together and position everything first to find the location for each one, making sure you can reach the shut off valves and that you can turn them off/on with all of then in place. Also leaving enough space to be able to reach the packing nut. Sometimes you have to bend a handle to work..
I think you only need to drill 2, just space them out, mark them. Drill a small pilot hole for each from the inside, then use a round hole saw bit from underneath.
Use a thick bead if 5200 around the base and then snug it up and let dry. Use some acetone to cleanup the excess on the bottom. I smear the excess around on the inside for extra protection..Last edited by parrothd; 05-25-2015 at 08:43 PM.
05-25-2015, 08:42 PM #9Senior Member
- Aug 2011
- 2,522
I have no new 90s, except for the original intake had one(I think). I have 4 total. There's videos on WakeMAKERS..
05-25-2015, 08:47 PM #10Senior Member
- Aug 2011
- 2,522
Oh and I use a little pipe dope on the threads, then your don't have to worry about leaks..
