Results 1 to 7 of 7
Thread: My auto flow got jacked!!!
05-25-2015, 04:15 AM #1
So went to surf today and my wave absolutely sucked. Looked at the auto flow settings and it said both were engaged. Wtf? Nothing seemed to fix it and the wave sucks now!
Sent from my iPhone using Tapatalk2015 Mondo
Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
2079 Prop
Auto Flow 2.0
Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
05-25-2015, 06:14 AM #2
Is there any way to manually disengage?
'06 Outback - Gone but not forgotten
'13 Mojo
05-26-2015, 01:35 AM #3
Well this morning I wiggled the plate on port side and noticed it was loose. You can see a gap between it and the fiberglass. Anyways after that I launched and it was back to normal...wtf? THEN late today we were surfing and I lost control of my trim tab. It was stuck all the way down. Tried turning off/on the engine and nothing. So after surfing I emptied the bags and turned off cruise control and the trim worked....wtf?
2079 Prop
Auto Flow 2.0
05-26-2015, 01:36 AM #4
Not sure how well this turned out
2079 Prop
Auto Flow 2.0
05-26-2015, 06:47 AM #5
I have a similar issue with my wake plate not working - in the engine compartment near the transom there is what looks like an ECU; it's actually the control module for the wake plate - the plug has a jumper (no idea why) and it doesn't snap into the harness correctly - cinch it together with a zip-tie and you should be golden.
2013 Outback V
05-26-2015, 07:49 AM #6
read the title and thought somebody stole your flow
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
05-26-2015, 07:57 AM #7
