Results 1 to 3 of 3
Thread: Perfect Pass
05-11-2015, 12:41 PM #1
Perfect Pass
Anyone know where the module is for the perfect pass. My LCD screen went out and I have to get the serial # from the module before I can order a replacement. Boat is an 07 Mobius LS if that helps for location. PP still works, just can't see what setting I'm on.
Thanks for any help.07 Mobius LS--Razorback Red
05-11-2015, 12:45 PM #2
I have a 2008 XLV and mine was located in the center under the helm to the rear of the steering wheel cable assembly.
It's up where all your wire harnesses are bundled up under the helm. Above where my sub box is.
This is what mine looked like:
Also, since you can see that there's a big plug called "display connector" then maybe check the harness plugs on the module and on the back of the display unit...2008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
www.TraysonsToybox.com
05-11-2015, 12:48 PM #3
Thanks. I'll check it when I get home this afternoon.
