Results 1 to 2 of 2
Thread: how to get to packing log
05-31-2006, 04:27 PM #1Junior Member
- May 2006
- 1
I am trying to get to the packing log on our 2000 moomba kanga but I cannot figure out how to pull the floor plate out to get to it. It started to take on water at a good rate and it has never been checked or serviced before. Any Ideas would be greatly apprciated.
05-31-2006, 09:58 PM #2Senior Member
- Sep 2002
- Pennsylvania
- 106
Replying to Topic 'how to get to packing log'
You will first need to remove the engine cover, and then loosen the 4 screws on the plate 2 up near the motor and the other 2 are probably under the rear bench. You should be able to work the plate forward from there. (this is how it came out on my 01 Outback LS, I would imagine it is similar on the Kanga)
Good luck, E
v-drive gland packing nut
By Yellowmobius in forum General ChatReplies: 3Last Post: 06-27-2006, 12:58 AM -
Shaft packing - what size?
By NH Moomba in forum Service & RepairReplies: 5Last Post: 04-26-2006, 07:35 PM -
Shaft Packing
By qb12 in forum Service & RepairReplies: 8Last Post: 06-10-2005, 05:47 PM -
Access the Shaft Log Packing Nut
By broncogeoff in forum Service & RepairReplies: 9Last Post: 05-06-2005, 06:52 PM -
Gland Packing nut
By Yellowmobius in forum Service & RepairReplies: 2Last Post: 06-11-2003, 11:42 AM
