Results 11 to 20 of 22
05-01-2015, 03:50 PM #11
I posted earlier but did not see my reply so lets try again,
I did order the Kicker KXM400.4 but have a question on install
since Fusion only has 1 output would the connection go
from fusion radio to existing 2 channel amp, then take the output from 2 channel to a RCA splitter and then to the AMP1 and AMP2 input on the new 4 channel?2015 Moomba Mondo Surf Edition
05-01-2015, 03:51 PM #12
05-01-2015, 03:56 PM #13
05-02-2015, 01:49 AM #14
15 moomba mondo - adding Bow Speaker
2015 Mondo
Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
2079 Prop
Auto Flow 2.0
Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
05-04-2015, 09:20 AM #15
05-04-2015, 10:21 AM #16
Does the existing Kicker amp have a pre-amp output? Which amp is it, can you tell? If it is one with a preamp out that is the best way to get signal to the KXM400.4. Otherwise, a set of y-cords will be needed to split the head unit signal to both amps. On the KXM400.4 there is a switch that allows a sinle set of RCA cables to drive all channels of the amp. On the FADER switch, simply push th button to the IN position instead of OUT.
I would have responded sooner, but somehow I did';t see this thread til this morning.
any questions, just holler
Phil
KickerLast edited by philwsailz; 05-04-2015 at 10:30 AM.
05-04-2015, 10:33 AM #17
Digging on my data, I believe you have a Kicker KX200.2 driving the tower speakers. Sound right? If so there is for sure an output on the KX200.2 for driving an additional amp. So, yes, just run an RCA cable from teh output of the KX200.2 to the AMP1 input of the KXM400.4.
FADER button in....
That should get you genning,...
Phil
Kicker
05-04-2015, 11:07 AM #18
I tried to upload a picture but it did not come through... take a peak @ my drawing (feel Free to laugh, I am a visual guy)
https://www.dropbox.com/s/9dgv4on41j...stall.jpg?dl=02015 Moomba Mondo Surf Edition
05-04-2015, 11:30 AM #19
Good pic, and that will work. I think you'll be happier if you installed a line driver to get the preamp voltage up though. Kicker's dual zone control would be an easy solution.
Edit: here is your pic
2 amp install.jpgLast edited by brain_rinse; 05-04-2015 at 11:44 AM.
05-04-2015, 11:38 AM #20
thanks for the info guys... I am more of a visual person and tried to post a picture or link and they said it would post pending approval but never saw them so maybe try it this way
add
www.
to the begining of the link below to see a very Rough (feel free to laugh) sketch of what i though i needed to do )
dropbox.com/s/9dgv4on41j9gvr5/2%20amp%20install.jpg?dl=02015 Moomba Mondo Surf Edition
