Results 1 to 10 of 16
04-29-2015, 04:21 PM #1Senior Member
- Jun 2007
- 883
Upgrading Kenwood KMR-550U to KMR-D562BT?
Does anyone know if the wiring harness is the same, and if the driver side controls are compatible?
http://www.kenwood.com/ca/car/marine/kmr-d562bt/2006 Moomba Mobius LSV
Stereo: Kenwood KMR-D562BT
Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
04-29-2015, 04:24 PM #2
it does not list steering wheel control, so I would assume it will not work with your driver side controls.
2017 Centurion Ri237
2013 Supra SA450 - Sold
2006 Mobius LSV - Sold
2004 Stingray 190LS - Sold
04-29-2015, 04:35 PM #3Senior Member
- Jun 2007
- 883
according to crutchfield.ca
Remote Control: The Kenwood KMR-D562BT offers remote compatibility through its wired remote input.
Optional Marine Wired Remote: The Kenwood KCA-RC35MR wired marine remote control (113RC35MR, sold separately) is designed to withstand the harsh marine environment. The Kenwood add-on wired remote features source selector, music search, and volume control buttons.
Optional Steering Wheel Control: The head unit's wired remote input wire (blue/yellow) also lets you keep your vehicle's factory radio steering wheel remote controls when used with an optional steering wheel audio control adapter (sold separately). Please consult Crutchfield's Outfit My Car to see if your vehicle is compatible.
wiring diagram on page 27 shows remote controls
http://manual.kenwood.com/files/B5A-0150-20.pdf2006 Moomba Mobius LSV
04-29-2015, 04:46 PM #4Senior Member
- Aug 2011
- 2,522
They all use the same harness..
2002 Moomba Mobius LSV - Sold
2006 Moomba Mobius LSV - Sold
04-29-2015, 04:53 PM #5Senior Member
- Jun 2007
- 883
04-30-2015, 08:46 AM #6Senior Member
- Jun 2007
- 883
order placed.. yay
05-02-2015, 07:11 PM #7Senior Member
- Jun 2007
- 883
Exact wire hardness. Beauty. Plug and play upgrade.
To note. The lead for the antenna form the head unit is built in now. Had to snip a zip tie to make the antenna cord reach.
Bluetooth grawesome to have2006 Moomba Mobius LSV
05-18-2015, 09:41 AM #8Member
- Apr 2009
- Raleigh, NC
- 62
I'm thinking about getting a KMR-D562BT as well. Do you have the Aeware TSC-55 wired driver side remote? If so, did it work with the new head unit?
Thanks,
Josh05 Mobius LSV - gravity 3 ballast and wake plate
single axle trailer
DIY hot water shower installed
DIY tube inflator installed
05-18-2015, 09:53 AM #9Senior Member
- Jun 2007
- 883
06-07-2015, 09:48 PM #10Junior Member
- May 2014
- Minnesota
- 26
Hi Spyder,
I too just bought the 562BT and put it in my 2006 Outback. Loved that it was plug n play, kind of.... My driver side and swim deck remotes don't work. You said modifications were needed on the harness when you went to the 550U. In doing that did you bring the connection for the remote into the main plug? Was it the blue wire with white stripe in the Moomba harness? That is the only thing that wasn't part of the main harness plug in. I didn't do anything to the moomba harness and I think it is all original. I hate to cut the original plug and start soldering stuff together but will do if I have to, just want to make sure I do the right thing.
