Results 11 to 12 of 12
Thread: Exile XM30.2 Amp Question....
04-25-2015, 01:56 PM #11
Ed - very easy setup on your XM30.2 That amp was designed with the tower zone in mind. The crossover actually starts @ 80hz. So there is zero guess work.
Set the amp to HighPass / HF
Bass boost off - this is not needed
start with a gain setting of 20%. If you are not running a line driver EQ you'll need a bit more. If your running an EQ you might need a touch less. You can msg me later and I can walk you thru your specific boat set up.
Brian
04-25-2015, 03:58 PM #12Banned
- May 2014
- Clermont, Fl
- 586
Thanks Brian!
No EQ on my boat.
