Results 1 to 10 of 16
Thread: Battery and Power wire gauge
04-19-2015, 02:12 AM #1
My current setup is as follows:
- Two marine deep cycle batteries (typical walmart/costco lead acid batteries)
- Perko switch
- Kicker 700.5 amp (class A/B for cabins, Class D for sub)
- Precision Power P600.2 (class D amp)
So when I took a look at my setup, I found that whoever did my stereo system wired the two amps with 4 gauge to a distribution block, then wired 4 gauge directly to one of my batteries. Both batteries are wired to the Perko switch with 4 gauge.
I think it's a poor design to have the amplifiers wired to bypass the switch, so I intend on re-wiring the lead from the distribution block to go to the perko switch. The run looks like it will end up being about 6 to 7 feet. Maybe 9 or 10 feet if I relocate the distribution block closer to the power terminals of the amps and in turn shortened the run from the distribution block to each of the amps.
What gauge wire should I run from:
- The batteries to the perko switch?
- From the Perko Switch to my amplifier distribution block?
- From the Distribution block to each of the amps?
www.TraysonsToybox.com
04-19-2015, 02:44 AM #2
I personally do not attach my Amps to the Perko switch. Only Batteries, and Alt.
From your batteries to the Perko 2 gauge
From the batteries to the Distro 2 gauge for 2 amps, if you goto larger amps, or more then 0 guage
I like to use the analogy of water pipes, if you have 2 houses that have a 4 inch pipes, then you want to use a pipe 2xs as big, which in Wires is 2 gauge.
I personally run my power and ground stereo distro to my + - battery terminals. Then I run the battery + to my perko for each bank respective to the Perko 1/2 sides.
If you wire the stereo to the common side of the Perko then the stereo will always be draining a battery and you won't be able to isolate it.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
04-19-2015, 06:13 AM #3
Unfortunately, 2 gauge does not carry twice the ampacity of 4 guage.
If we stick to the middle of the ampacity chart and use the values for 75 degree C wire @ an air temp of 86 degrees F, then the ampacities are:
4 gauge = 125 amps
2 gauge = 170 amps
0 gauge (1/0) = 230 amps
00 gauge (2/0) = 265 amps
If you use 90 degree wire, the ampacity values are higher.
I would run 1/0 directly from the battery to the distribution block and 4 gauge from the distribution block to the amps. 1/0 to 4 gauge distribtion blocks are easy to find on Ebay.Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
04-19-2015, 08:14 AM #4If you wire the stereo to the common side of the Perko then the stereo will always be draining a battery and you won't be able to isolate it
For the sake of clarity, lets assume the audio is wired direct to #2 battery. You can swap the #1 and #2 in my examples if one likes, as the scenario would be the same
*When wired battery direct, the battery cannot be isolated from the loads
*When the switch is turned #1, boat draws from #1, audio still draws from #2 but alternator only charges #1, audio battery goes dead
*When switch is on #2 boat and audio draw from #2 and alternator charges #2
*When turned to BOTH or 1/2, depending on your switch nomenclature, audio and boat draw from BOTH batteries and alternator charges boat while engine is running
* When switch is OFF, audio still draws from #2.
The dual battery switch is nothing more than a manual isolator. If you wire loads battery direct, you bypass the switch, reducing the function of the switch. With all loads on the common, OFF isolates the batteries from all loads. When set to 1 or 2, the other battery will be isolated from all loads.
Not trying to pick on you Mike. Your system is not wrong, just not ideal IMO, but your statement was not accurate regarding wiring loads to the common of the switch.
Tryson,
I would suggest 1/0 for the battery+ cables and the B- linking the battery grounds. I would also suggest using 1/0 for the amps B+ and B- trunk lines. Way overkill for the current setup given the distance, but plenty of room for future growth. 4ga would likely be borderline minimum, 2ga would be most accurate if you crunched the numbers, but since you are already needing 1/0 for the battery cables. Not a huge difference in cost to just purchase 1/0 for amp trunk line and battery cables.
4ga branch lines from the distribution blocks to the amps.
04-19-2015, 08:27 AM #5Banned
- May 2014
- Clermont, Fl
- 586
speaking of distribution blocks - can you guys suggest one that has a minimum of 1/4" terminal studs and possibly a cover?
I need to cut down on the number of cables connected to the perko..
Trayson - would it be possible to put up a picture of the one you use?
04-19-2015, 09:00 AM #6
No I get your point, and you are right. I do mine differently but the way you are describing does allow 100% isolation when in the OFF position. That is the idea goal.
I wire mine more so its completely isolates my stereo from the starter battery. This way I never have a chance at a dead starter battery.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
04-19-2015, 10:11 AM #7This way I never have a chance at a dead starter battery.
In order for your stereo bank to receive any charge from the alternator when the engine is running, you would have to run with the switch in BOTH or what ever bank your amps are wired to. If running on BOTH and if you drop anchor and forget to switch from BOTH, the stereo is still drawing from both banks.
A system with the least amount of chance for the stereo to run down the cranking, would be a dual circuit plus switch an ACR. Beyond that, you would have to have a stand-alone bank.
04-19-2015, 11:36 AM #8Banned
- May 2014
- Clermont, Fl
- 586
My stereo is wired isolated from the starter battery...My starter battery died on me while on the lake this past Friday. Started the boat from the stereo battery.
Thank god for two batteries!!
04-19-2015, 04:00 PM #92008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
04-19-2015, 04:03 PM #10
I also have this that runs straight off one of the batteries and goes... Somewhere??? It goes from battery to breaker and then the output disappears down into the hull.
What does it do? And based on that I'll figure out if that should go to the perko switch as well.
(yes, I know what a circuit breaker does, but what is this trying to accomplish with my boat and should it be able to be isolated with the perko as well?)
