04-13-2015, 01:17 AM #1
Anybody add an in floor table mount?
I've seen a lot of boats with it (factory) but haven't seen any more to get one in? Has anyone done one?
2015 Mondo
Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
2079 Prop
Auto Flow 2.0
Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
04-13-2015, 10:09 AM #2
You see them more often on tuners and deck boats that run with sort of a flat attitude. Our boats tend to run nose high due to ballast, etc. Often they are listed to the surf side as well. This makes keeping anything on the table while underway almost impossible.
04-13-2015, 11:08 AM #3
My friend's sky Supreme has one factory. No reason one couldn't be put in. And kane, it's not something you'd use when you were underway. And if we're listed, it's to surf, we empty ballast to put the boat level if we want to eat.
www.TraysonsToybox.com
04-13-2015, 12:09 PM #4
Malibu's have the table also. You would have to check the measurement between the top of the fuel tank and the top of the floor to see if a pocket for a table post would fit. Pull the cover for the center hull drain and measure. You should be able to get all the parts needed from an RV dealer or online.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
04-13-2015, 12:25 PM #5
When I bought my boat someone had screwed one of these into to floor of the port rear locker. The only thing I can think of is they made a table that could be screwed into it when parked and then removed will under way.
http://m.homedepot.com/p/Mueller-Glo...3HN/100188066/2008 LSV on the way out
'17 CRAZ!!! on the way in
