Results 1 to 10 of 12
Thread: Exile gear just arrived!!
04-10-2015, 11:47 PM #1Senior Member
- Jan 2014
- Kelowna, BC Canada
- 426
2014 Black/White Mojo
345HP Surf Motor
1235 Prop
Autoflow 2.0 Upgrade
1100# FlyHigh Rears
650# IBS
4 x Exile SXT9q's w/ Exile 30.2 amp and Exile ZLD controller
Exile Javelin Amp
10" Rockford sub
04-10-2015, 11:55 PM #2
Awesome congratz
[COLOR="#696969"]
04-11-2015, 12:08 AM #3
Pretty sure that won't suck.
www.TraysonsToybox.com
04-11-2015, 12:12 AM #4Senior Member
- Jan 2014
- 426
Any threads with tricks on how to fish the wire?
What do you guys recommend for wire? It already has 18 gauge (i think?) from the factory towers.
Going to eventually get a light bar as we get in a lot of night runs so would make sense to run the power for that at the same time?2014 Black/White Mojo
345HP Surf Motor
1235 Prop
1100# FlyHigh Rears
650# IBS
Exile Javelin Amp
10" Rockford sub
04-11-2015, 12:33 AM #5
If running new I'd run 12AWG through the tower so it can take just about whatever you want to put up there.
If already run with 14 or 16 AWG I'd probably just tie in and couple the line. If it truly is 18awg, I'd tether it with 12
AWG and pull a new line all the way through.
For LED they only need 20 or 22AWG so not biggie there especially if already wired. Tie that in with the 12AWG and your golden. If you use 4-conductor that would cover 2 sets pretty easy on LED and 4 conductor 12AWG is easy to fish and take care of the speakers.Last edited by viking; 04-11-2015 at 12:38 AM.
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
04-11-2015, 12:41 AM #6
I'm assuming you already have wire in tower. Hook on and pull through!
If NOT ............. use a small piece of plastic tied to end of line and use a vacuum to suck it through through the tower. Worked like a charm for me!!
Good lucK!
2015 "NOT A MOOMBA"
04-11-2015, 09:39 AM #7
Enjoy the project and the end result! Awesome gear
2022 Moomba Mojo
2013 Moomba Mojo 2.5 (sold)
Tow - 2019 Ford F150 Ecoboost
04-11-2015, 01:20 PM #8Senior Member
- Jan 2014
- 426
great thanks for the info. gonna get started on it this wknd.
FYI - any of you guys that are close to the border ... with the shitty Canadian dollar I ended up paying $1475.00US for this package. Not sure what kind of taxes etc you pay coming across but that's about $1000 off.2014 Black/White Mojo
345HP Surf Motor
1235 Prop
1100# FlyHigh Rears
650# IBS
Exile Javelin Amp
10" Rockford sub
04-11-2015, 01:23 PM #9Senior Member
- Jan 2014
- 426
345HP Surf Motor
1235 Prop
1100# FlyHigh Rears
650# IBS
Exile Javelin Amp
10" Rockford sub
04-13-2015, 09:49 AM #10
Congrats on your Exile setup. I'm sure you will love it. Be sure to share some pix when you get them on the tower.
