Results 1 to 10 of 11
04-06-2015, 09:14 PM #1Member
- May 2013
- Denton, TX
- 55
Exile clamps not fitting my tower.
We installed my exile tower speakers today and the clamp all the way down with the smaller screws were still loose. I even wrapped a spongy material around it with no luck.
Anybody have this problem?
Dylan
2012 MOOMBA LSV
04-06-2015, 09:35 PM #2
Contact Brian @ Exile, you have the same tower as I (non-HD). They have smaller clamps that will work like a charm.
2022 Moomba Mojo
2013 Moomba Mojo 2.5 (sold)
Tow - 2019 Ford F150 Ecoboost
04-06-2015, 10:10 PM #3Member
- May 2013
- Denton, TX
- 55
Thank you sir
Dylan
2012 MOOMBA LSV
04-07-2015, 06:31 AM #4
I suggest putting some type of rubber material in between regardless of clamp size. Prevent scratching the powder coat.
Sent from my iPhone using TapatalkShane
2016 Supra SE
EXILED
6 XM9 Tower
6 Wetsounds XS650 Cabin
1 EXILE BIG 12 DVC 2000 watt in a ported box
1 XM 15.4
XI 1500.1
2 MX 30.2
Wetsounds 420 EQ
EXILE Blue tooth EXBT4
Blue LEDs
04-11-2015, 11:53 AM #5Senior Member
- May 2014
- Hoover, Al
- 588
04-11-2015, 12:08 PM #6
http://m.grainger.com/mobile/categor...ecatalog/N-c1z
Or plumbing ferncos-Jake
04-11-2015, 12:11 PM #7Senior Member
- May 2014
- Hoover, Al
- 588
04-11-2015, 12:15 PM #8
Most rubber sheet material gets a bit slimy in the hot sun and actually promotes slippage rather than stopping it.
For any speaker that has the wire concealed through the collar, slippage (vertical speaker rotation) can cause damage by tearing the wire away from the fine pins that the wire is soldered to.
Try a 'silicone rubber' sheet. It doesn't seam to be affected by the heat. You can usually find this at a good old fashion hardware store.
04-11-2015, 12:17 PM #9Senior Member
- May 2014
- Hoover, Al
- 588
04-11-2015, 12:39 PM #10
It should also be mentioned that the thin pliable rubber sheet material is a consideration for protecting the tower finish, but in no way should be considered a substitute for changing to the correct collar size as recommended above.
