Thread: Mondo Oil/Transmission Fluid
04-05-2015, 09:46 PM #1
1) Do most of you guys change your own fluids or should I just take it and have it done. Local shops are charging ~$170.
2) How easy it?
SurfSon
2014 Mondo
04-06-2015, 07:43 AM #2Senior Member
- Oct 2004
- Middle TN
- 148
If you have the right equipment it is easy, just need something to suck the oil out.
04-06-2015, 08:19 AM #3
Yes, very easy to do, several videos.
2014 Mojo Surf
2013 Mojo Sold
2010 LSV Sold
2002 OB LSV Sold
04-06-2015, 09:34 AM #4
Most of the guys on here do it themselves. Get yourself a large capacity oil sucker ~ $50-70 and a funnel Then all you need is oil and an oil filter. It will save you time as it only takes about 15 minutes to do for the engine, and 10 for each of the vdrive and tranny. Shell rotella is used by many without problem for a 15w40. The only issue some have had is getting the oil filter off, make sure you lube the gasket on the new one, and use the easy drain tube from the bottom of the oil pan and not the dipstick tube.
09 21v LAUNCH
99 Outback LS. Sold
Doug
