Results 1 to 3 of 3
Thread: How too remove gunwhale padding
04-03-2015, 05:29 AM #1
seems it would be easier if gunwhale padding was removed for new speaker install! what s the secret?
2013 Moomba Mojo 2.5 surf motor
Flow added
Exile ZLD 2
Exile javelin
Exile 30.2
Exile sx65
Exile XM9s
12" exile DVC
Led Lights
04-03-2015, 05:16 PM #2
Have a look - https://forum.moomba.com/showthread....=mojo+speakers
Lots of Mojo owners here will chime in I'm sure. I've helped a buddy do this in an I/O runabout. Taped over the vinyl. Used a box knife to outline the cutout. Then a holesaw to actually cut through and take the foam out. Probably could have done the foam carving with a box knife but his was clean with the holesaw and also had to go through fiberglass.So when is this "old enough to know better" supposed to kick in?
04-03-2015, 11:50 PM #3
On my LSV, I had to remove the grab handle and some of the lower panel screws. It gave me enough room to get the cabin speakers in and out. Remove the seat cushions, and you can lay in the underseat storage area. Look up inside, and you will see all the hardware.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
