Thread: Flow on Outback V
03-28-2015, 06:01 AM #1Member
- Oct 2013
- Gladwin/Calumet, MI
- 75
Flow on Outback V
I was thinking about adding flow to my 13 OBV. Has anyone added to the outback or surfed behind one. The dealer has one I can demo when the ice melts but that will only have stock ballast. I currently have 750 rears 400 center and IBS. Just curious if it worth it.
1988 Ski Centurion Falcon
2013 Moomba Outback V
03-28-2015, 02:00 PM #2
Flow on Outback V
I was about to pull the trigger on the Flow for my '13 OBV until I found out you have to also replace the platform too for another $850 or so. I would definitely be interested in what you find out about its performance though so please share!!
Mike
2013 Outback V
- FAE
- DIY suckgate
03-28-2015, 03:44 PM #3Member
- Oct 2013
- 75
Did they say why the platform needs to be replaced. When i saw the 15 with flow i did not notice anything different. If I stop by the dealer again i will check that out. If that is the case i can say not worth it.
03-29-2015, 08:45 AM #4Member
- Oct 2013
- 75
Mike,
I was looking at photos of 15 and the platform has angles cut back at the transom for the flow. Looking at them I am not convinced that it is needed. I think it is so the handle on the flow does not hit the platform. At first glance I am thinking you could remove the handle and/or put a new hole in the plate so it locks just before it hits the platform. (if it does not stick out past the side of the transom). I also noted that the LSV has the same platform shape as ours and flow works. I think the flow mounts lower compared to the platform on the OBV causing the issue.1988 Ski Centurion Falcon
03-29-2015, 09:50 AM #5
Flow on Outback V
I think you are right with all the thoughts above -- I thought about trying it without changing the platform but it seems the Flow now comes in a "kit" that includes the platform and I couldn't get two dealers I inquired to to sell me the Flow without the rest of that kit. Let me know if you find out otherwise.
Mike
2013 Outback V
- FAE
- DIY suckgate
